Network and Storage Protocols
HTTP Authentication using NTLM failed
leonardo_m
Dear NetApp Users,
I have a problem with the Data ONTAP built in HTTP Web Server.
The authentication is not working properly. For example: Once that the user was authenticated he can access any folder independent of the share permission configuration, or be, the user can access folders which they wouldn´t.
The following message is shown:
Wed Jul 13 11:15:34 BRT [HTTPPool00:warning]: HTTP Authentication from XXX.XXX.XXX.XXX using NTLM failed
I use the CIFS Authentication which works without problems.
Some usefull information:
NETFAS 2020
NetApp Release 7.3.2
Domain type: Windows 2003
Authentication type: Active Directory
Security Style: NTFS Only
*The domain server firewall is disabled for now.
httpd.access                 legacy
httpd.admin.access           legacy
httpd.admin.enable           on
httpd.admin.hostsequiv.enable off
httpd.admin.max_connections  512
httpd.admin.ssl.enable       on
httpd.admin.top-page.authentication on
httpd.autoindex.enable       on
httpd.bypass_traverse_checking off
httpd.enable                 on
httpd.ipv6.enable            off
httpd.log.format             common
httpd.method.trace.enable    on
httpd.rootdir                /vol/rdstorage1/
httpd.timeout                900
httpd.timewait.enable        off
cifs.LMCompatibilityLevel    1
cifs.audit.account_mgmt_events.enable on
cifs.audit.autosave.file.extension
cifs.audit.autosave.file.limit 0
cifs.audit.autosave.onsize.enable off
cifs.audit.autosave.onsize.threshold 75%
cifs.audit.autosave.ontime.enable off
cifs.audit.autosave.ontime.interval 1d
cifs.audit.enable            off
cifs.audit.file_access_events.enable on
cifs.audit.liveview.allowed_users
cifs.audit.liveview.enable   off
cifs.audit.logon_events.enable on
cifs.audit.logsize           1048576
cifs.audit.nfs.enable        off
cifs.audit.nfs.filter.filename
cifs.audit.saveas            /etc/log/adtlog.evt
cifs.bypass_traverse_checking on
cifs.client.dup-detection    ip-address
cifs.comment                 Storage Comment
cifs.enable_share_browsing   on
cifs.gpo.enable              off
cifs.gpo.trace.enable        off
cifs.grant_implicit_exe_perms off
cifs.guest_account
cifs.home_dir_namestyle      ntname
cifs.home_dirs_public_for_admin on
cifs.idle_timeout           1800
cifs.ipv6.enable             off
cifs.max_mpx                 50
cifs.ms_snapshot_mode        xp
cifs.netbios_aliases         XXX.XXX.XXX.XXX
cifs.netbios_over_tcp.enable on
cifs.nfs_root_ignore_acl     off
cifs.oplocks.enable          on
cifs.oplocks.opendelta       0
cifs.per_client_stats.enable off
cifs.perm_check_ro_del_ok    off
cifs.perm_check_use_gid      on
cifs.preserve_unix_security  off
cifs.restrict_anonymous      0
cifs.restrict_anonymous.enable off
cifs.save_case               on
cifs.scopeid
cifs.search_domains
cifs.show_dotfiles           on
cifs.show_snapshot           on
cifs.shutdown_msg_level      2
cifs.sidcache.enable         on
cifs.sidcache.lifetime       1440
cifs.signing.enable          off
cifs.smb2.client.enable      off
cifs.smb2.durable_handle.enable on
cifs.smb2.durable_handle.timeout 16m
cifs.smb2.enable             off
cifs.smb2.signing.required   off
cifs.snapshot_file_folding.enable off
cifs.symlinks.cycleguard     on
cifs.symlinks.enable         on
cifs.trace_dc_connection     on
cifs.trace_login             off
cifs.universal_nested_groups.enable on
cifs.weekly_W2K_password_change off
cifs.widelink.ttl            10m
I´ve tried to change some values unsuccessfully.
Do you have any tip about the problem?
Regards,
Leonardo Maia
1 ACCEPTED SOLUTION
muhammad_i_pasha
Share permissions only come into effect when you access data through that share. Have you tried NTFS permissions?
2 REPLIES 2
muhammad_i_pasha
leonardo_m
Yes, it worked fine with the NTFS permissions.
I thought that DATA ONTAP Share Configurations should works with the HTTP authentication, however in my case, the HTTP authentication only worked properly with the NTFS permissions.
Thank you!
