Network and Storage Protocols
Help commands
cn1610
problems, to find the support for the cn1610 team, I need to download the firewall and I also need to delete all the configuration of a single port to leave it default but without affecting the whole team.
1 REPLY 1
donny_lang
I'm not exactly certain what you mean by "download the firewall" (if you can elaborate I'll be happy to try to help), but you can find the port configuration commands - and perhaps the answer to your other question - in the CN1610 Administrator's Guide at: https://library.netapp.com/ecm/ecm_download_file/ECMP1117874
