Network and Storage Protocols
How to delete WINS IP-addresses?
sanadmin_stadtdo
Hi,
in our environment WINS server were used in the past, which are already deleted and do no longer exist. In the existing CIFS-vFiler these IP-addresses are still included and causes the following warnings in the syslog: "NBT: No WINS server are responding The filer will continue to try to register with WINS.." (nearly every minute)
options cifs.wins_servers supplies the two IP-addresses 172.17.40.2,172.17.40.3.
a) How to delete these IP-addresses?
b) Do I have to rerun the CIFS-Setup on the vFiler?
c) It's a reboot or cifs shutdown required?
Thank you very much.
Regards.
Michael
1 ACCEPTED SOLUTION
warrenb
Hi Michael,
I wasn't aware of that, but after a little digging I've found that whilst you can only view cifs.wins_servers from vfiler0 you can still set it in a vfiler. See here: https://library.netapp.com/ecmdocs/ECMM1278014/html/vfiler/basica18.htm#1155735
Whilst you cannot use cifs.wins_servers to view the information you should be able to use nbtstat to list WINS servers: -
labstorage*> vfiler run vf_warrenb options cifs.wins_servers 10.68.30.56
labstorage*> vfiler run vf_warrenb nbtstat
===== vf_warrenb
interfaces:
         10.68.30.127
broadcast interfaces:
         10.68.30.255
servers:
         10.68.30.56 (active)
NBT scope []; NBT mode [H]; NBT names:
         VF_WARRENB      <00> ( Broadcast ) ( )
         VF_WARRENB      <03> ( Broadcast ) ( )
         VF_WARRENB      <20> ( Broadcast ) ( )
         COV-LAB         <00> ( Broadcast ) ( group )
labstorage*> vfiler run vf_warrenb options cifs.wins_servers ""
===== vf_warrenb
interfaces:
         10.68.30.127
         10.68.30.255
servers:
Regards,
Warren
3 REPLIES 3
warrenb
Hi Michael,
You should be able to clear the option using an empty string: -
Regards,
Warren
sanadmin_stadtdo
Hallo Warren,
I forgot: options cifs.wins servers provides the IP addresses 172.17.40.2,172.17.40.3 only on the filer0 and not to the respective vFiler.
It seems that there is no such option on the vFiler (eg fsdeg006😞
     fsdeg006@NA325012> options cifs.wins_servers
     No such option cifs.wins_servers
     fsdeg006@NA325012>
     fsdeg006 @ NA325012>
     fsdeg006 @ NA325012> options cifs
     cifs.LMCompatibilityLevel 2
     cifs.universal_nested_groups.enable on
     cifs.widelink.ttl 10m
Where are these IP addresses stored in the vFiler (which were registered with the CIFS Setup)?
Do the IP addresses will be deleted only on the filer0?
Thank you.
Regards,
Michael
warrenb
Hi Michael,
===== vf_warrenb
interfaces:
         10.68.30.127
         10.68.30.255
servers:
===== vf_warrenb
interfaces:
         10.68.30.127
         10.68.30.255
servers:
Regards,
Warren
