Network and Storage Protocols
Ifgrp VLAN failover group
NetApp93
Good Afternoon,
Been looking through documentation and KB's but cannot find an answer to this seemingly simple question. Currently building out an AFF-A150 for a HW refresh of an AFF-A220 running NFS for a vCenter datastore. We have two ifgroups with vlan 30 (a0a-30) on each node, with e0c/e0d as apart of each a0a on each node. Each a0a-30 has a data LIF sitting on top of it. Pretty simple.
I was reviewing the configuration of the AFF-A220 that we are replacing and realized that for some reason in the data broadcast domain, we had not only both a0a-30 ports but also both a0a ports. This is actually my first time building out a new system from scratch - is this something that is required when including a VLAN port sitting on top of an ifgroup to a failover group, including the underlying ifgroup as well? To me that doesn't make any sense, as a the data LIF, which is obviously running frames with a vlan 30 tag, could failover to an a0a port where the frames would then be dropped. Am I missing something here regarding how failover groups should be configured, or is my AFF-A220 misconfigured?
1 ACCEPTED SOLUTION
chamfer
Good Afternoon @NetApp93 ,
Just to help others who come across this post we should define broadcast domains and failover groups:
Broadcast Domain: "Broadcast domains are intended to group network ports that belong to the same layer 2 network. The ports in the group can then be used by a storage virtual machine (SVM) for data or management traffic."
Failover Group: "You create a failover group of network ports so that a LIF can automatically migrate to a different port if a link failure occurs on the LIF's current port. This enables the system to reroute network traffic to other available ports in the cluster."
Answer to original question: If all of your data LIFs are VLAN tagged then you do not need a broadcast domain or Failover Group configured for your untagged interface group (a0a in your case).  I have run into issues in the past when configuring IPspaces on interface groups where broadcast domains were required as it was being configured, but can be removed post IPspace configuration.
Q:  To me that doesn't make any sense, as a the data LIF, which is obviously running frames with a vlan 30 tag, could failover to an a0a port where the frames would then be dropped. Am I missing something here regarding how failover groups should be configured, or is my AFF-A220 misconfigured?
A: When you create a broadcast domain for your VLAN you should have a failover group created, you can show this with the "failover-groups show" command.  Each VLAN that you configure on ONTAP should have its own broadcast domain and failover group and these would be separate from the broadcast domain and failover group that are automatically created on your interface group (a0a) so you don't need to worry about your data LIF failing over to the a0a ports with frames being dropped.
Does this answer your questions?
2 REPLIES 2
chamfer
NetApp93
Thanks chamfer!
Definitely answers my question regarding failover groups. I really meant broadcast-domains, but I know the failover group members are the broadcast domain members, should have clarified that. I'll make sure to ensure that only my ifgrp VLAN ports are in the same broadcast-domain lest we failover to the lower level "naked" ifgrp. Cheers!
