Network and Storage Protocols
Is QoS compatible with pNFS in cDOT8.3 and cDOT8.3.1?
Dong_Chen
IHAC is test QoS in cDOT831P1. I found the TR-4211 of performance primer cDOT8.3(Page18)
"QoSpolicies are applicable to all supported protocols, including NFS, SMB, SAN, iSCSI, and FCoE. Starting in clustered Data ONTAP 8.3, NFS 4.1 is supported.
Note:  QoS is not compatible with NFS 4 prior to clustered Data ONTAP 8.3.
         QoS is not compatible with pNFS in clustered Data ONTAP."
So I have a test of QoS and pNFS. It seems that the QoS policy group works in the pNFS access. Both in the direct LIF mount or the indirect LIF mount, the QoS throughput did limit the IO.
So, what does the incompatibility between QoS and pNFS ly in, the limitation or something else? Or QoS is supported with nNFS?
Here are the output,
step 1, enable nfsv4,v4.1,v4.1-pnfs,
cluster1::*> nfs show -fields  v4.0,v4.1,v4.1-pnfs  -vserver svm1
vserver v4.0    v4.1    v4.1-pnfs
svm1    enabled enabled enabled
cluster1::*> vol show -fields qos-policy-group  -volume vol1
vserver volume qos-policy-group
svm1    vol1   qp1                                         -> QoS policy group “qp1” with the limitation of 1MB/s
cluster1::*> qos policy-group show
Name             Vserver     Class        Wklds Throughput
qp1              svm1        user-defined 1     0-1MB/s
[root@rhel1 /]# mount -t nfs -o vers=4.1 svm1:/vol1 /vol1             -> mount with 4.1 option in RHEL6.5 host
svm1:/vol1 on /vol1 type nfs (rw,vers=4,minorversion=1,addr=192.168.0.140,clientaddr=192.168.0.61)
[root@rhel1 /]#
[root@rhel1 vol1]# dd if=/dev/zero of=q3 bs=1M count=30
30+0 records in
30+0 records out
31457280 bytes (31 MB) copied, 70.9384 s, 443 kB/s                -> dd test the file creation while the rate without QoS limitation is 145 MB/s
[root@rhel1 vol1]# dd if=/dev/zero of=q2 bs=1M count=300
30+0 records in
30+0 records out
314572800 bytes (315MB) copied, 272.228 s, 1.2 MB/s
cluster1::*> qos statistics volume performance show                  -> qos statistics display the throughput is around 1MB/s
Workload            ID     IOPS       Throughput    Latency
-total-              -        0            0KB/s        0ms
-total-              -       15       981.33KB/s      1.69s
vol1-wid8129      8129       15       981.33KB/s      1.69s
-total-              -       17      1109.33KB/s      3.91s
vol1-wid8129      8129       17      1109.33KB/s      3.91s
-total-              -        6       362.67KB/s      2.56s
vol1-wid8129      8129        6       362.67KB/s      2.56s
-total-              -       13       810.67KB/s   374.49ms
vol1-wid8129      8129       13       810.67KB/s   374.49ms
-total-              -       17      1088.00KB/s      1.91s
vol1-wid8129      8129       17      1088.00KB/s      1.91s
1 ACCEPTED SOLUTION
Dong_Chen
Thanks for the replying, I have got the confirmation that NFS 4.1 and pNFS are now supported in clustered Data ONTAP 8.3.1+. In clustered Data ONTAP 8.3 only NFS 4.1 was supported.
2 REPLIES 2
Renifa
Hi,
pNFS support began in clustered Data ONTAP 8.1 for files only and continues with enhancements in clustered Data ONTAP 8.2. There is no Data ONTAP 7G/7-Mode support for pNFS. Current client support
for pNFS is very limited, but NetApp does support all clients that support pNFS and follow the RFC specifications. By default the pNFS option is enabled, but it is only active if NFSv4.0 and NFSv4.1 support also are enabled. NetApp does not currently recommend pNFS for metadata-heavy workloads. pNFS requires a client that also supports pNFS. Currently, RHEL 6.4 is the only commercial Linux distribution that has full pNFS support. Check the link for more info "http://www.cptech.com/wp-content/uploads/2014/06/Clustered-Data-on-Tap.pdf"
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Dong_Chen
