Network and Storage Protocols
Issues creating Active Directory entries and vservers
NetappGuy7
Hi,
Unfortunately, the issues are rather layered. Recently, we started receiving the following message:
CENCOLO-02: None of the LSA servers configured for Vserver X are currently accessible via the network. Run vserver cifs domain discovered-servers show to see the list of discovered servers. Also, check EMS event log to see the possible cause of errors on these servers. Alert Received on: Wed Jul 12 2023 12:14 PM.
We weren't sure how to address this, so we started deleting and recreating the Active Directory entries in order to address this. However, we ran into another issue attempting to do so:
In order to create an Active Directory machine account for the CIFS server, you must supply the name and password of a Windows account with sufficient privileges to
add computers to the "OU=Census, OU=Servers" container within the "STATCAN.CA" domain.
Enter the user name: (username)
Enter the password:
Error: Machine account creation procedure failed
[ 0 ms] Trying to create machine account 'X' in
'STATCAN.CA' for Vserver 'X'
**[ 6015] FAILURE: Unable to contact DNS to discover domain
** controllers.
[ 6015] Unable to connect to any (0) domain controllers.
[ 9021] Unable to contact DNS to discover domain controllers.
[ 15031] No servers available for MS_LDAP_AD, vserver: 37, domain:
STATCAN.CA.
Error: command failed: Failed to create the Active Directory machine account "X". Reason: SecD Error: no server available.
It seems to be a DNS issue, and when we checked, we were treated with this:
cencolo::> vserver services name-service dns check -vserver X
Name Server
Vserver Name Server Status Status Details
X down Operation timed out.
10.X.X.X
10.X.X.X
2 entries were displayed.
Please advise!
1 ACCEPTED SOLUTION
NetappGuy7
I apologize for the late reply, but it seems the issue is a result of this:
SU530: [Impact Critical] NTLM authentication fails due to enforcement of Netlogon RPC sealing (Microsoft CVE-2022-38023) - NetApp Knowledge Base
Thank you very much for your support, but I know what needs to be done now. A software update is in order.
Than
4 REPLIES 4
NetappGuy7
Good morning
Thank you for the quick response. I've checked the solutions but they didn't solve the issue.
Running the command suggested gives me this:
vserver services name-service dns check -vserver X Name Server
X 10.125.36.10 down Operation timed out.
X 10.125.36.11 down Operation timed out.
The DNS servers can be pinged... there's nothing wrong with them. But for whatever reason, we're at an impasse
Ontapforrum
The output 'Operation timed out' clearly suggests SVM is unable to talk to DNS servers? When you says DNS server can be pinged ? From where are you pinging it? Could you show us the output.
Also, share the output of the following along with PING :
::> network interface show -vserver <cifs svm> -fields service-policy
::> network route show -vserver <cifs svm>
NetappGuy7
Than
