Network and Storage Protocols
Management Console no longer displays queue depth (system:pa_concurrency)
jeff_spiegel
I had a custom view setup for queue depth (system:pa_concurrency).  It was working fine and then we upgraded to On Command 5.0.  Now the charts are blank and I get no data.  Tried deleting and re-creating with no luck.  I tried going to Setup - Hosts - and editing the data collection but when I look at system I don't see pa_concurrency (it is not listed as either disabled or enabled).  Not sure if it is supposed to be there or not?   Any help would be appreciated.  Thanks!  Jeff
3 REPLIES 3
jeff_spiegel
I think I just found a clue.  When I try to recreate the chart it shows pa_concurrency in italics (which means data collection is disabled).  So that is why I have no data.  Now.....to figure out how to turn it on since I did not see it as an option the last time I looked.
agireesh
Counter "pa_concurrency" is a calculate stat counter, this counter value calculated using below counters.So, please make sure that perf data collection is enabled for below counters.
nfsv3_avg_op_latency
nfsv3_ops
nfsv4_avg_latency
nfsv4_ops
cifs_latency
cifs_ops
iscsi_read_latency
iscsi_read_ops
iscsi_write_latency
iscsi_write_ops
fcp_read_latency
fcp_read_ops
fcp_write_latency
fcp_write_ops
Regards,
Gireesh
reide
Gireesh,
I have confirmed that Performance Advisor is collecting all of the counters you listed.  However, when I attempt to add the pa_concurrency counter to a chart, its still shown in italics.  When I move my mouse over the counter it states "...(Data collection currently disabled).".   What am I missing that enables the pa_concurrency counter in OnCommand 5.0?  My controllers are all ONTAP 8.1RC2.
