Network and Storage Protocols
Multistore failover fails
JOHANNESWOLF
Hi together,
got a massive problem when i failover a customer MetroCluster 3140. All the cifs-vfilers didnt failover.
The customer creates the vfilers with Systemmanager 2.0 😞  so i repair the rc file and the ipspace list, but this didnt solve the issue.
Everytime after a failover when i check the vfiler status -r on partner side there stand unconfigured
The ipadresses are correct and the vfilers running, but the ipadress didnt get matched on a interface.
Maybe you have a solution?
Here are ifconfig -a / ipspacelist /etc/rc  and etc/hosts
Thanks
Joe
hostname NetApp03
ifgrp create lacp VIF1 e2a e2b
vlan create VIF1 106 107 108 117 251 301 401 503
ifconfig VIF1-301 192.168.242.105 netmask 255.255.255.0 partner VIF1-301
ifconfig VIF1-107 192.168.7.105 netmask 255.255.255.0 partner VIF1-107
ifconfig VIF1-401 192.168.240.125 netmask 255.255.255.0 partner VIF1-401
ifconfig VIF1-251 192.168.201.105 netmask 255.255.255.0 partner VIF1-251
ifconfig VIF1-117 partner VIF1-117
ifconfig VIF1-106 partner VIF1-106
ifconfig VIF1-503 partner VIF1-503
ifconfig VIF1-108 partner VIF1-108
route add default 192.168.242.1 1
vfiler run Firstxpstore route add default 192.168.7.1 1
vfiler run DSIMstore route add default 192.168.201.1 1
vfiler run NMSstore route add default 192.168.240.1 1
routed on
options dns.domainname xxx.xxx
options dns.enable on
options nis.enable off
NetApp03> ipspace list
Number of ipspaces configured: 8
default-ipspace                   (e0a e0b e0M losk VIF1 VIF1-301)
DSIMstore                         (VIF1-251)
Firstxpstore                      (VIF1-107)
nmsstore                          (VIF1-401)
Edmstore                          (VIF1-108)
EEOstore                          (VIF1-117)
Firstxtstore                      (VIF1-106)
Scalastore                        (VIF1-503)
e0a: flags=0x2f08866<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        ether 00:a0:98:0b:6a:4c (auto-1000t-fd-up) flowcontrol full
e0b: flags=0x2f08866<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        ether 00:a0:98:0b:6a:4d (auto-1000t-fd-up) flowcontrol full
e2a: flags=0x89f08867<BROADCAST,RUNNING,MULTICAST,TCPCKSUM,VLAN> mtu 1500
        ether 02:a0:98:0b:6a:4c (auto-10g_sr-fd-up) flowcontrol full
        trunked VIF1
e2b: flags=0x89f08867<BROADCAST,RUNNING,MULTICAST,TCPCKSUM,VLAN> mtu 1500
        trunked VIF1
e0M: flags=0x2b08866<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        ether 00:a0:98:0b:6a:4e (auto-100tx-fd-up) flowcontrol full
lo: flags=0x1b48049<UP,LOOPBACK,RUNNING,MULTICAST,TCPCKSUM> mtu 8160
        inet 127.0.0.1 netmask 0xff000000 broadcast 127.0.0.1
        ether 00:00:00:00:00:00 (VIA Provider)
losk: flags=0x40a400c9<UP,LOOPBACK,RUNNING> mtu 9188
        inet 127.0.20.1 netmask 0xff000000 broadcast 127.0.20.1
VIF1: flags=0xa2f08863<BROADCAST,RUNNING,MULTICAST,TCPCKSUM,VLAN> mtu 1500
        ether 02:a0:98:0b:6a:4c (Enabled interface groups)
VIF1-107: flags=0x2b48863<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 192.168.7.105 netmask 0xffffff00 broadcast 192.168.7.255
        partner VIF1-107 (not in use)
VIF1-108: flags=0x2308862<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
VIF1-117: flags=0x2308862<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
VIF1-251: flags=0x2b48863<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 192.168.201.105 netmask 0xffffff00 broadcast 192.168.201.255
        partner VIF1-251 (not in use)
VIF1-301: flags=0x2b48863<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 192.168.242.105 netmask 0xffffff00 broadcast 192.168.242.255
        partner VIF1-301 (not in use)
VIF1-401: flags=0x2b48863<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 192.168.240.125 netmask 0xffffff00 broadcast 192.168.240.255
        partner VIF1-401 (not in use)
VIF1-503: flags=0x2308862<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
VIF1-106: flags=0x2308862<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
127.0.0.1 localhost
192.168.242.105 NetApp03 NetApp03-VIF1
# 0.0.0.0       NetApp03-e0M
# 0.0.0.0       NetApp03-e2a
# 0.0.0.0       NetApp03-e2b
192.168.115.10  xxxxxx  mailhost
192.168.242.106  NetApp04
172.16.20.125   NetApp03-VIF1-503
192.168.4.140   NetApp03-VIF1-108
hostname NetApp04
ifconfig VIF1-301 192.168.242.106 netmask 255.255.255.0 partner VIF1-301
ifconfig VIF1-117 192.168.117.106 netmask 255.255.255.0 partner VIF1-117
ifconfig VIF1-106 192.168.6.106 netmask 255.255.255.0 partner VIF1-106
ifconfig VIF1-503 172.16.20.125 netmask 255.255.255.0 partner VIF1-503
ifconfig VIF1-108 192.168.4.140 netmask 255.255.255.128 partner VIF1-108
ifconfig VIF1-107 partner VIF1-107
ifconfig VIF1-401 partner VIF1-401
ifconfig VIF1-251 partner VIF1-251
vfiler run Firstxtstore route add default 192.168.6.1 1
vfiler run EEOstore route add default 192.168.201.1 1
vfiler run Scalastore route add default 172.16.20.1 1
vfiler run Edmstore route add default 192.168.4.128 1
routed on
NetApp04> ipspace list
Edmstore                          (VIF1-108)
EEOstore                          (VIF1-117)
nmsstore                          (VIF1-401)
        ether 00:a0:98:0b:6a:3c (auto-1000t-fd-up) flowcontrol full
        ether 00:a0:98:0b:6a:3d (auto-1000t-fd-up) flowcontrol full
        ether 02:a0:98:0b:6a:3c (auto-10g_sr-fd-up) flowcontrol full
        trunked VIF1
        trunked VIF1
        ether 00:a0:98:0b:6a:3e (auto-100tx-fd-up) flowcontrol full
        ether 02:a0:98:0b:6a:3c (Enabled interface groups)
VIF1-106: flags=0x2b48863<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 192.168.6.106 netmask 0xffffff00 broadcast 192.168.6.255
        partner VIF1-106 (not in use)
VIF1-107: flags=0x2308862<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
VIF1-108: flags=0x2b48863<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 192.168.4.140 netmask 0xffffff80 broadcast 192.168.4.255
        partner VIF1-108 (not in use)
VIF1-117: flags=0x2b48863<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 192.168.117.106 netmask 0xffffff00 broadcast 192.168.117.255
        partner VIF1-117 (not in use)
VIF1-251: flags=0x2308862<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 192.168.242.106 netmask 0xffffff00 broadcast 192.168.242.255
VIF1-401: flags=0x2308862<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
VIF1-503: flags=0x2b48863<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 172.16.20.125 netmask 0xffffff00 broadcast 172.16.20.255
        partner VIF1-503 (not in use)
#Auto-generated by setup Thu Dec 30 16:37:00 GMT 2010
127.0.0.1 localhost
192.168.242.106 NetApp04 NetApp04-VIF1
# 0.0.0.0       NetApp04-e0M
# 0.0.0.0       NetApp04-e2a
# 0.0.0.0       NetApp04-e2b
192.168.115.10  xxxxx  mailhost
192.168.242.208 NetApp04-e2a
192.168.242.20  NetApp04-e2b
172.16.20.106   NetApp04-VIF1-503
192.168.4.140   NetApp04-VIF1-108
3 REPLIES 3
brauntvr2swiss
Hi Joe
Could you run a vfiler status -r on both Filers and put the output in this thread?
Does all vfiers Fails (unconfigured) during a takeover or only a few?
regards
Thomas
pauli
Hi Joe,
it is clear that you got in Trouble! On Controller 03 there area few Partner IF missing in ifconfig!
Even if you have them in rc file, if the are not set, you will get in Trouble durring Failover.
   after the giveack, there are set because they are in rc file. Check with ifconfig -a!
BTW:  I always tell my customer to add an IP address to the VIFS, even if they are not used! So they can ping from
Controller to Controller to check if the Network Interfaces work and if the vlans are Setup on both side!
     This prevent from Problems like the vlans are not configured on the Switch on the side where the Controller is with "normally" no IP address.
Thanks,
Horst
JOHANNESWOLF
Sry the customer has no direct internet connection and i cant get some output from my office.
But i know that all vfilers are in unconfigured status during a takeover. I´ll send the customer a mail, maybe he can send me the informations.
regards
joe
