Network and Storage Protocols
NDMP Restore on Ontap 8.1 with Arcserve R16
rstone_de
Hi,
after updating our FAS 3040C to Ontap 8.1 I'm not able to do a restore on this FAS anymore.I get the following error message in the Arcserve job log:
AE0407 NAS Server Error - NDMP_DATA_HALT_INTERNAL_ERROR.
Restores on older version of Ontap (7.33 & 8.0) are successful.
Any ideas?
regards
Richard
1 ACCEPTED SOLUTION
hannig
I had the same Problem and  found  this and now it works fine.
1) Restore fails with error AE0407 for all Filer2Server sessions located on tape sequences higher than sequence 1 >> Technical support test fix T146582 being validated
2) Restore fails on ONTAP 8.1.1 >> T146581 being validated
You can contact Technical Support if you are in the cases reported above.
9 REPLIES 9
RCMERRY12
I am having the same issue with 8.1.1 and Arcserve R16 SP1.
RCMERRY12
I figured it out. When restoring do no select the entire volume drill down and just select all the folders off the base and it then it restored for me.
rstone_de
It works half right for me: your way is fine on CIFS but I'm not able to restore LUNs .
UTRAUTMANN
Where is your lun located? In a Volume or Qtree?
rstone_de
Volume
hannig
rstone_de
Thanks, after installing both of the fixes it works fine.
felsbergnetapp
Hi,
I had the same problem, but with dataontap 8.0.2, this fix  could solve my problem too ?
DENISOZORIO
Hello Guys!
Sorry for ask this here, but what yours rate in NDMP backups to ArcServer R16 ?
Here, I don´t get more than 50MB/Minute in my Backups.
