Network and Storage Protocols
NFS Export Permission for Unix
tumma
Hi,
We hava Netapp Simulator with Data ONTAP 8.2.1 and trying to creata NFS export and mount on Unix system but geting permission denied error.
Here is the configuration
exportfs cofiguration
NetApp3> exportfs
/vol/DEST_NFS -sec=sys,rw
/vol/CLI -sec=sys,rw
/vol/new -sec=sys,rw
/vol/new2 -sec=sys,rw
NetApp3>
Mounting NFS on Linux
from the above exports, mounted /vol/DEST_NFS in Linux
[root@localhost /]# mount -t nfs 192.168.4.59:/vol/DEST_NFS /nfsshare/
[root@localhost /]# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/centos-root 50G 6.6G 44G 14% /
devtmpfs 895M 0 895M 0% /dev
tmpfs 904M 728K 903M 1% /dev/shm
tmpfs 904M 8.8M 895M 1% /run
tmpfs 904M 0 904M 0% /sys/fs/cgroup
/dev/mapper/centos-home 246G 76G 170G 31% /home
/dev/sda1 497M 160M 338M 33% /boot
192.168.4.59:/vol/DEST_NFS 973M 192K 973M 1% /nfsshare
[root@localhost /]# cd nfsshare/
[root@localhost nfsshare]# mkdir test
mkdir: cannot create directory ‘test’: Permission denied
If we create a qtree under the /vol/DEST_NFS volume and export the NFS, we are able to read and write the filers and folders.
Please suggest, whether the above procedure is correct or we missing someting.
Regards,
Sunil Tumma
6 REPLIES 6
JGPSHNTAP
Did you turn NFS on?
tumma
Yes.
Here is the output
NetApp3> nfs status
NFS server is running.
rwelshman
try
exportfs -p rw=<server ip>,root=<server ip> /vol/DEST_NFS
tumma
Hi,
We dont want to give root permission, can we access volume the with default RW permission.
Regards,
Sunil Tumma
tumma
OK.
The query is, Can i mount NFS export on Linux systems without Qtree?
If i create Qrtree under a Volume, i can able to mount and access NFS on linux systems with default permisson(rw=hstname, no root aceess), but in my case if i directly mount a volume without qtree, i am able to mount but unable to access with (rw=hostname, no root access) permissions.
Regards,
Sunil Tumma
asdfjkl
exportfs -c should be used to ascertain whether or not the client has the correct permissions, but in your case I would guess that you haven't given yourself root access, so the root user is treated as nobody.
