Network and Storage Protocols
NFS shared volume fine but permission denied when access
penangmis
We are running on 8.2.3P4 7-Mode FAS2554.
We tried to shared a volume /vol/BKP_engnfs as below in /etc/exportfs :
/vol/BKP_engnfs -sec=sys,rw,root=<ipaddress>
We are able to mount from the linux client without issue.
mount filer:/vol/BKP_engnfs /engnfs2
However when we cd /engnfs2, we get permission denied.
Any idea what is missing?
We have this shared in our old 7.2.3 7-Mode FAS2020, without issue.
2 REPLIES 2
mbeattie
Hi,
The first thing i'd check is the security style of the volume. EG
controller1> vfiler run vfiler1 qtree status
Check that the volume and any qtrees within the volume have the security type of "unix".
By default they will inherit the security style of the vfiler.
If they are set to ntfs then change the volume and qtree security style to unix. EG
controller1> vfiler run vfiler1 qtree security /vol/vol1 unix
controller1> vfiler run vfiler1 qtree security /vol/vol1/qtree1 unix
Hope that helps
/matt
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
penangmis
Consider close.
It's weird wafl.default_security_style is already set to unix
However the volume get set to nfts.
Have to check the qtree permission setting correctly. Change it to unix or ntfs accordingly.
qtree
qtree security /vol/[vol_name] unix
or
qtree security /vol/[vol_name] ntfs
hope this help
