Network and Storage Protocols
NT4 and CIFS
antonywardle
Hi
Anyone running an NT4 system and using NetApp CIFS?
Wanting to know if it is supported I guess that NT4 is using
an older version of SMB so the filer would need to be running SMB1?
Filer versions of Ontap that I am running are 7.3.5.1P5 and 8.0.1P2 and no
I can't upgrade the server from NT4.
Is there a certification guide on the now site anywhere?
cheers
antony
3 REPLIES 3
radek_kubka
Hi and welcome to the Community!
First of all, as you probably know, NT4 is no longer supported by Microsoft.
Secondly, the oldest version of Microsoft server OS listed on NetApp compatibility matrix is 2000 SP4.
That being said, it quite likely will work (with some possible quirks).
Regards,
Radek
antonywardle
Thanks for that.
do you have a  link to the matrix?
cheers
antony
antonywardle
never mind I think i found it here
http://now.netapp.com/matrix/mtx/login.do
thanks once again
