Network and Storage Protocols
No access to locked files (not file permission problem)
atle
We have a customer who frequently reports he cannot access files using Computer Management in Windows (CIFS). Has anybody experienced this or know a solution to this?
We have found this temporarily solution: 'lock status -p cifs' and then  'lock break -f '<file>' -p cifs
Running ONTAP 7.3.1.1
2 REPLIES 2
Jeff_Yao
this is actually as the messages says "diff user and pwd are using". that's why u cant access the filer with administration permission.
from that windows system, use "net use" command to check connections you setup with the filer.....
u can use "net use  /delete" to delete the connection on the IPC$ ...
then use "net use \\filer /user:abc", abc is the user has permission to administer the filer.........
HENRYPAN2
Cool YaoGuang,
That's the way it should be.
Happy 2012
Henry PAN
