Network and Storage Protocols
Ontap 8.3 direct connect FC to a Win2008R2 box
ilonak
Customer wants to direct attach FC to Windows 2008 R2 server with two QLogic cards.  Looking for KB/instructions to accomplish this if possible.
Currently have 0c from each of the two nodes connected to the QLogic cards on the Win box.  As a test/control, 0d is connected to a Brocade switch.  "fcadmin" shows all 4 ports online, but "adapter show -instance" only shows the ports connected to the Brocade switch as connected.  What am I missing?
1 ACCEPTED SOLUTION
shatfield
"Direct-attached configurations are not supported."  See pg 11:
https://library.netapp.com/ecm/ecm_download_file/ECMP1636036
I don't think you'll get very far with direct attached NPIV.
4 REPLIES 4
aborzenkov
Do you use 16G adapters on NetApp side by any chance?
ilonak
Yes, they sent 16Gb SFP+ adapters for both the NetApp and the Windows box.  I was assured that they would automatically adjust to the lowest common denominator (in this case, 8Gb).
shatfield
ilonak
Well, that solves that 🙂  I read through that doc, but didn't catch that.  Thanks!
