Network and Storage Protocols
PA and protocol latency reporting
jkennedy_4
What does the "Average Latency per Protocol" graph/stat truly indicate in PA for NFS?
Is it latency for every NFS op that it's satisfying?  Some of them?  The highest latent operation?
I don't fully understand it because in PA, and running sysstat, there can be things going on that all seem to be happening very quickly, yet latency is huge.  I mean in the tens of thousands of microseconds.
The particular case in question is attached as png (hopefully).
Thanks.
2 REPLIES 2
aborzenkov
10 thousands of microseconds is not huge. It is just 10ms, which is not spectacular, but far below "huge".
jkennedy_4
If it were only 10k microseconds, maybe. But note the png I attached to the post, it shows 25k-35k microseconds. 25-35 milliseconds is pretty darned huge.
Jeff Kennedy
Qualcomm, Incorporated
QCT Engineering Compute
858-651-6592
