Network and Storage Protocols
Problem Accessing CIFS Shares
flash3313
We had to restart our FAS2020. Now, users are no longer able to access the shares we created. We can ping the ip address of the FAS, but when we do \\IP Address we cannot open up the share folder any more. Any ideas? Thanks
1 ACCEPTED SOLUTION
reena
On the FAS Console, type "cifs domaininfo".
Reena
7 REPLIES 7
reena
Can you check the "CIFS domaininfo" on the FAS to see if anything abnormal in seeing the FAS participation in the domain ?
Reena
flash3313
Where am I looking to check that information?
reena
Reena
flash3313
Reena, thank you for your help. When I tyoed in CIFS Domaininfo, an error came back saying the time on the FAS was more than 5 minutes different from the domain. I fixed the time and now all the shares are working again. Thanks again!
dakenah_johnson
Reena,
thanks for the post. I am experiencing the same problem on my fas 2020. How do I correct the time?
Thanks,
Doc
addanki
Use the command “date” to manually adjust the time.
Srinivas
sigmajdblock
It is good that you were able to set the time and regain access to your CIFS shares, but the best solution to this is to setup a NTP server or setup the FAS2020 to point at the same NTP server that your domain is getting it's time from.  This would keep your FAS2020 and your domain on the same time so the issue doesn't happen again.
John
