Network and Storage Protocols
Problem with configuring FAS270 with AD
kaspersky
Details:
Model:   FAS270
Version: 7.3.7
Domain functional level: Windows server 2003
Forest functional level: Windows server 2003
DC2 is 2K12 R2
DC1 is 2K3 R2
cannot be able to configure FAS270 with active directory, please help.
Community rocks!!
CIFS - Starting SMB protocol...
[FASNEW: cifs.homedir.badEntry:error]: CIFS: Bad entry /vol/vol0TESTDIR while processing home directory paths. Homedir path doesn't exist, discarding this entry.
[FASNEW: auth.dc.trace.DCConnection.statusMsg:info]: AUTH: TraceDC- Starting DC address discovery for FOREST.
[FASNEW: auth.dc.trace.DCConnection.statusMsg:info]: AUTH: TraceDC- Found 2 addresses using DNS site query (Default-First-Site-Name)..
[FASNEW: auth.dc.trace.DCConnection.statusMsg:info]: AUTH: TraceDC- Found 2 addresses using generic DNS query.
[FASNEW: auth.dc.trace.DCConnection.statusMsg:info]: AUTH: TraceDC- Starting WINS queries.
[FASNEW: auth.dc.trace.DCConnection.statusMsg:info]: AUTH: TraceDC- Found 2 BDC addresses through WINS.
[FASNEW: auth.dc.trace.DCConnection.statusMsg:info]: AUTH: TraceDC- Found 1 PDC addresses through WINS.
[FASNEW: auth.dc.trace.DCConnection.statusMsg:info]: AUTH: TraceDC- DC address discovery for FOREST complete. 2 unique addresses found.
[FASNEW: cifs.auditfile.enable.on:info]: ALF: CIFS auditing started.
[FASNEW: nbt.nbns.registrationComplete:info]: NBT: All CIFS name registrations have completed for the local server.
[FASNEW: cifs.server.infoMsg:info]: CIFS: Warning for server \\DC1: Connection terminated.
[FASNEW: cifs.server.infoMsg:info]: CIFS: Warning for server \\DC1: Unable to create NETLOGON pipe No Trusted Logon Servers Available - STATUS_NO_LOGON_SERVERS.
FASNEW: cifs.server.infoMsg:info]: CIFS: Warning for server \\DC2: Connection terminated.
[FASNEW: cifs.server.infoMsg:info]: CIFS: Warning for server \\DC2: Unable to create NETLOGON pipe No Trusted Logon Servers Available - STATUS_NO_LOGON_SERVERS.
Welcome to the FOREST.CORP (FOREST) Active Directory(R) domain.
FASNEW> cifs domaininfo
[FASNEW: auth.ldap.trace.LDAPConnection.statusMsg:info]: AUTH: TraceLDAPServer- Starting AD LDAP server address discovery for FOREST.CORP.
[FASNEW: auth.ldap.trace.LDAPConnection.statusMsg:info]: AUTH: TraceLDAPServer- Found 2 AD LDAP server addresses using DNS site query (Default-First-Site-Name).
[FASNEW: auth.ldap.trace.LDAPConnection.statusMsg:info]: AUTH: TraceLDAPServer- Found 2 AD LDAP server addresses using generic DNS query.
[FASNEW: auth.ldap.trace.LDAPConnection.statusMsg:info]: AUTH: TraceLDAPServer- AD LDAP server address discovery for FOREST.CORP complete. 2 unique addresses found.
NetBios Domain: FOREST
Windows 2003 Domain Name: forest.corp
Type: Windows 2003
Filer AD Site: Default-First-Site-Name
Not currently connected to any DCs
Preferred Addresses:
None
Favored Addresses:
192.168.1.111 DC1 PDCBROKEN
192.168.1.112 DC2 PDCBROKEN
Other Addresses:
None
Connected AD LDAP Server: \\dc2.forest.corp
None
Favored Addresses:
192.168.1.112
dc2.forest.corp
192.168.1.111
dc1.forest.corp
Other Addresses:
None
FASNEW> cifs testdc
Using Established configuration
Current Mode of NBT is H Mode
Netbios scope ""
Registered names...
FASNEW < 0> WINS
FASNEW < 3> WINS
FASNEW <20> WINS
FOREST < 0> WINS
ACSFAS < 0> WINS
ACSFAS < 3> WINS
ACSFAS <20> WINS
Testing all Primary Domain Controllers
found 2 unique addresses
found PDC DC2 at 192.168.1.112
found PDC DC1 at 192.168.1.111
Testing all Domain Controllers
found DC DC2 at 192.168.1.112
found DC DC1 at 192.168.1.111
FASNEW> cifs resetdc
Disconnecting from domain FOREST...
Reconnecting to domain FOREST...
 [FASNEW: cifs.server.infoMsg:info]: CIFS: Warning for server \\DC2: Connection terminated.
Reconnection failed!
FASNEW> options
acp.domain 0
acp.enabled off
acp.netmask 0
acp.port
auditlog.enable on (value might be overwritten in takeover)
auditlog.max_file_size 10000000 (value might be overwritten in takeover)
auditlog.readonly_api.enable off (value might be overwritten in takeover)
autologout.console.enable on (value might be overwritten in takeover)
autologout.console.timeout 60 (value might be overwritten in takeover)
autologout.telnet.enable on (value might be overwritten in takeover)
autologout.telnet.timeout 60 (value might be overwritten in takeover)
autosupport.cifs.verbose off
autosupport.content complete
autosupport.doit CHASSIS POWER SUPPLY FAIL: PS 1
autosupport.enable on
autosupport.from your.name@your.domain.com
autosupport.local.nht_data.enable off
autosupport.local.performance_data.enable off
autosupport.mailhost 192.168.1.114
autosupport.minimal.subject.id hostname
autosupport.nht_data.enable on
autosupport.noteto
autosupport.partner.to
autosupport.performance_data.enable on
autosupport.retry.count 15 (value might be overwritten in takeover)
autosupport.retry.interval 4m (value might be overwritten in takeover)
autosupport.support.enable on
autosupport.support.proxy
autosupport.support.to autosupport@netapp.com
autosupport.support.transport https
autosupport.support.url support.netapp.com/asupprod/post/1.0/postAsup
autosupport.throttle on
autosupport.to your.name@your.domain.com
backup.log.enable on
bootfs.chkdsk_enabled off (value might be overwritten in takeover)
cdpd.enable off (value might be overwritten in takeover)
cdpd.holdtime 180 (value might be overwritten in takeover)
cdpd.interval 60 (value might be overwritten in takeover)
cf.giveback.auto.cifs.terminate.minutes 5
cf.giveback.auto.enable off
cf.giveback.auto.terminate.bigjobs on
cf.giveback.check.partner off
cf.hw_assist.enable off
cf.hw_assist.partner.address
cf.hw_assist.partner.port 0
cf.nodestatus.enable off (value might be overwritten in takeover)
cf.quickloop.enable false (same value required in local+partner)
cf.takeover.change_fsid on
cf.takeover.detection.seconds 20
cf.takeover.on_disk_shelf_miscompare off
cf.takeover.on_failure on
cf.takeover.on_network_interface_failure off
cf.takeover.on_network_interface_failure.policy all_nics (same value in local+partner recommended)
cf.takeover.on_panic off
cf.takeover.on_short_uptime on
cf.takeover.use_mcrc_file off (value might be overwritten in takeover)
cifs.LMCompatibilityLevel 1
cifs.audit.account_mgmt_events.enable off
cifs.audit.autosave.file.extension
cifs.audit.autosave.file.limit 0
cifs.audit.autosave.onsize.enable off
cifs.audit.autosave.onsize.threshold 75%
cifs.audit.autosave.ontime.enable off
cifs.audit.autosave.ontime.interval 1d
cifs.audit.enable on
cifs.audit.file_access_events.enable on
cifs.audit.liveview.allowed_users
cifs.audit.liveview.enable off
cifs.audit.logon_events.enable on
cifs.audit.logsize 524288
cifs.audit.nfs.enable off
cifs.audit.nfs.filter.filename
cifs.audit.saveas /etc/log/adtlog.evt
cifs.bypass_traverse_checking on
cifs.client.dup-detection ip-address
cifs.comment
cifs.enable_share_browsing on
cifs.gpo.enable off
cifs.gpo.trace.enable off
cifs.grant_implicit_exe_perms off
cifs.guest_account
cifs.home_dir_namestyle domain
cifs.home_dirs_public_for_admin on
cifs.idle_timeout 1800
cifs.ipv6.enable off
cifs.max_mpx 50
cifs.ms_snapshot_mode xp
cifs.netbios_aliases ACSFAS
cifs.netbios_over_tcp.enable off
cifs.nfs_root_ignore_acl off
cifs.oplocks.enable off
cifs.oplocks.opendelta 0
cifs.per_client_stats.enable off
cifs.perfmon.allowed_users
cifs.perm_check_ro_del_ok off
cifs.perm_check_use_gid on
cifs.preserve_unix_security off
cifs.restrict_anonymous 0
cifs.restrict_anonymous.enable off
cifs.save_case on
cifs.scopeid
cifs.search_domains acs.co.il,forest.corp
cifs.show_dotfiles on
cifs.show_snapshot off
cifs.shutdown_msg_level 2
cifs.sidcache.enable on
cifs.sidcache.lifetime 1440
cifs.signing.enable on
cifs.smb2.client.enable off
cifs.smb2.durable_handle.enable on
cifs.smb2.durable_handle.timeout 16m
cifs.smb2.enable on
cifs.smb2.signing.required on
cifs.snapshot_file_folding.enable off
cifs.symlinks.cycleguard on
cifs.symlinks.enable on
cifs.trace_dc_connection on
cifs.trace_login on
cifs.universal_nested_groups.enable off
cifs.weekly_W2K_password_change off
cifs.widelink.ttl 10m
cifs.wins_servers 192.168.1.111
cksum_offload.gbeII off
console.encoding nfs
coredump.dump.attempts 2 (value might be overwritten in takeover)
disk.asup_on_mp_loss on (value might be overwritten in takeover)
disk.auto_assign on (value might be overwritten in takeover)
disk.maint_center.allowed_entries 1 (value might be overwritten in takeover)
disk.maint_center.enable on (value might be overwritten in takeover)
disk.maint_center.max_disks 84 (value might be overwritten in takeover)
disk.maint_center.rec_allowed_entries 5 (value might be overwritten in takeover)
disk.maint_center.spares_check on (value might be overwritten in takeover)
disk.powercycle.enable on (value might be overwritten in takeover)
disk.recovery_needed.count 5 (value might be overwritten in takeover)
dns.cache.enable on (value might be overwritten in takeover)
dns.domainname forest.corp (value might be overwritten in takeover)
dns.enable on (value might be overwritten in takeover)
dns.update.enable on (value might be overwritten in takeover)
dns.update.ttl 24h (value might be overwritten in takeover)
ems.autosuppress.enable on (value might be overwritten in takeover)
ems.autosuppress.exempt_events (value might be overwritten in takeover)
fcp.enable off
flexcache.access none
flexcache.deleg.high_water 90
flexcache.deleg.low_water 50
flexcache.enable off
flexcache.per_client_stats on
flexscale.enable off (same value in local+partner recommended)
flexscale.lopri_blocks off (same value in local+partner recommended)
flexscale.normal_data_blocks on (same value in local+partner recommended)
flexscale.pcs_high_res off (same value in local+partner recommended)
flexscale.pcs_size 0GB (same value in local+partner recommended)
fpolicy.enable on
fpolicy.i2p_ems_interval 60
fpolicy.multiple_pipes on
ftpd.3way.enable off
ftpd.anonymous.enable off
ftpd.anonymous.home_dir
ftpd.anonymous.name anonymous
ftpd.auth_style mixed
ftpd.bypass_traverse_checking off
ftpd.dir.override
ftpd.dir.restriction off
ftpd.enable off
ftpd.explicit.allow_secure_data_conn on
ftpd.explicit.enable off
ftpd.idle_timeout 900s (value might be overwritten in takeover)
ftpd.implicit.enable off
ftpd.ipv6.enable off
ftpd.locking none
ftpd.log.enable on
ftpd.log.filesize 512k
ftpd.log.nfiles 6
ftpd.max_connections 400 (value might be overwritten in takeover)
ftpd.max_connections_threshold 75% (value might be overwritten in takeover)
ftpd.tcp_window_size 32768
httpd.access legacy
httpd.admin.access legacy
httpd.admin.enable on
httpd.admin.hostsequiv.enable off
httpd.admin.max_connections 512
httpd.admin.ssl.enable on
httpd.admin.top-page.authentication on
httpd.autoindex.enable on
httpd.bypass_traverse_checking off
httpd.enable off
httpd.ipv6.enable off
httpd.log.format common (value might be overwritten in takeover)
httpd.method.trace.enable off
httpd.rootdir XXX
httpd.timeout 300 (value might be overwritten in takeover)
httpd.timewait.enable off (value might be overwritten in takeover)
ic.carnegie.enable on (value might be overwritten in takeover)
interface.blocked.cifs
interface.blocked.ftpd
interface.blocked.iscsi
interface.blocked.mgmt_data_traffic off (value might be overwritten in takeover)
interface.blocked.ndmp
interface.blocked.nfs
interface.blocked.snapmirror
ip.fastpath.enable on (value might be overwritten in takeover)
ip.icmp_ignore_redirect.enable off (value might be overwritten in takeover)
ip.ipsec.enable off
ip.match_any_ifaddr on (value might be overwritten in takeover)
ip.path_mtu_discovery.enable on (value might be overwritten in takeover)
ip.ping_throttle.alarm_interval 0 (value might be overwritten in takeover)
ip.ping_throttle.drop_level 10 (value might be overwritten in takeover)
ip.tcp.newreno.enable on (value might be overwritten in takeover)
ip.tcp.sack.enable on (value might be overwritten in takeover)
ip.v6.enable off (value might be overwritten in takeover)
ip.v6.ra_enable on (value might be overwritten in takeover)
iscsi.enable on
iscsi.isns.rev 18
iscsi.max_connections_per_session use_system_default
iscsi.max_error_recovery_level use_system_default
kerberos.file_keytab.enable off
kerberos.file_keytab.principal
kerberos.file_keytab.realm
kerberos.replay_cache.enable off
ldap.ADdomain
ldap.base
ldap.base.group
ldap.base.netgroup
ldap.base.passwd
ldap.enable off
ldap.minimum_bind_level anonymous
ldap.name
ldap.nssmap.attribute.gecos gecos
ldap.nssmap.attribute.gidNumber gidNumber
ldap.nssmap.attribute.groupname cn
ldap.nssmap.attribute.homeDirectory homeDirectory
ldap.nssmap.attribute.loginShell loginShell
ldap.nssmap.attribute.memberNisNetgroup memberNisNetgroup
ldap.nssmap.attribute.memberUid memberUid
ldap.nssmap.attribute.netgroupname cn
ldap.nssmap.attribute.nisNetgroupTriple nisNetgroupTriple
ldap.nssmap.attribute.uid uid
ldap.nssmap.attribute.uidNumber uidNumber
ldap.nssmap.attribute.userPassword userPassword
ldap.nssmap.objectClass.nisNetgroup nisNetgroup
ldap.nssmap.objectClass.posixAccount posixAccount
ldap.nssmap.objectClass.posixGroup posixGroup
ldap.passwd ******
ldap.port 389
ldap.servers
ldap.servers.preferred 192.168.1.112
ldap.ssl.enable off
ldap.timeout 20
ldap.usermap.attribute.unixaccount unixaccount
ldap.usermap.attribute.windowsaccount windowsaccount
ldap.usermap.base
ldap.usermap.enable off
locking.grace_lease_seconds 45 (value might be overwritten in takeover)
lun.clone_restore on (value might be overwritten in takeover)
lun.partner_unreachable.linux.asc 0x4 (value might be overwritten in takeover)
lun.partner_unreachable.linux.ascq 0x1 (value might be overwritten in takeover)
lun.partner_unreachable.linux.behavior error (value might be overwritten in takeover)
lun.partner_unreachable.linux.hold_time 5 (value might be overwritten in takeover)
lun.partner_unreachable.linux.scsi_status 0x2 (value might be overwritten in takeover)
lun.partner_unreachable.linux.skey 0x2 (value might be overwritten in takeover)
lun.partner_unreachable.vmware.behavior error (value might be overwritten in takeover)
lun.partner_unreachable.vmware.hold_time 1 (value might be overwritten in takeover)
lun.partner_unreachable.vmware.scsi_status 0x8 (value might be overwritten in takeover)
lun.partner_unreachable.xen.asc 0x4 (value might be overwritten in takeover)
lun.partner_unreachable.xen.ascq 0x1 (value might be overwritten in takeover)
lun.partner_unreachable.xen.behavior error (value might be overwritten in takeover)
lun.partner_unreachable.xen.hold_time 5 (value might be overwritten in takeover)
lun.partner_unreachable.xen.scsi_status 0x2 (value might be overwritten in takeover)
lun.partner_unreachable.xen.skey 0x2 (value might be overwritten in takeover)
lun.use_partner.cc.bytes 512000 (value might be overwritten in takeover)
lun.use_partner.cc.enable on (value might be overwritten in takeover)
lun.use_partner.cc.warn_limit 10 (value might be overwritten in takeover)
ndmpd.access all
ndmpd.authtype challenge
ndmpd.connectlog.enabled off
ndmpd.data_port_range all
ndmpd.enable on
ndmpd.ignore_ctime.enabled off
ndmpd.offset_map.enable on
ndmpd.password_length 16
ndmpd.preferred_interface disable (value might be overwritten in takeover)
ndmpd.tcpnodelay.enable off
nfs.acache.persistence.enabled on (value might be overwritten in takeover)
nfs.always.deny.truncate on (value might be overwritten in takeover)
nfs.assist.queue.limit 40 (value might be overwritten in takeover)
nfs.export.allow_provisional_access on (value might be overwritten in takeover)
nfs.export.auto-update on (value might be overwritten in takeover)
nfs.export.exportfs_comment_on_delete on (value might be overwritten in takeover)
nfs.export.harvest.timeout 1800 (value might be overwritten in takeover)
nfs.export.neg.timeout 3600 (value might be overwritten in takeover)
nfs.export.pos.timeout 36000 (value might be overwritten in takeover)
nfs.export.resolve.timeout 30 (value might be overwritten in takeover)
nfs.hide_snapshot off
nfs.ifc.rcv.high 98910
nfs.ifc.rcv.low 33170
nfs.ifc.xmt.high 16
nfs.ifc.xmt.low 8
nfs.ipv6.enable off
nfs.kerberos.enable off
nfs.locking.check_domain on (value might be overwritten in takeover)
nfs.max_num_aux_groups 32
nfs.mount_rootonly on
nfs.mountd.trace off
nfs.netgroup.strict off
nfs.notify.carryover on
nfs.ntacl_display_permissive_perms off (value might be overwritten in takeover)
nfs.per_client_stats.enable off
nfs.require_valid_mapped_uid off
nfs.response.trace off (value might be overwritten in takeover)
nfs.response.trigger 60 (value might be overwritten in takeover)
nfs.rpcsec.ctx.high 0
nfs.rpcsec.ctx.idle 360
nfs.tcp.enable on
nfs.thin_prov.ejuke off (value might be overwritten in takeover)
nfs.udp.enable on
nfs.udp.xfersize 32768 (value might be overwritten in takeover)
nfs.v2.df_2gb_lim off (value might be overwritten in takeover)
nfs.v2.enable on (value might be overwritten in takeover)
nfs.v3.enable on (value might be overwritten in takeover)
nfs.v4.acl.enable off (value might be overwritten in takeover)
nfs.v4.enable off (value might be overwritten in takeover)
nfs.v4.id.domain acs.co.il
nfs.v4.read_delegation off (value might be overwritten in takeover)
nfs.v4.write_delegation off (value might be overwritten in takeover)
nfs.webnfs.enable off
nfs.webnfs.rootdir XXX
nfs.webnfs.rootdir.set off
nis.domainname
nis.enable off
nis.group_update.enable off
nis.group_update_schedule 24
nis.netgroup.domain_search.enable on
nis.netgroup.legacy_nisdomain_search.enable on
nis.servers *
nis.slave.enable off
nlm.cleanup.timeout 100
nlm.trace off
pcnfsd.enable off (value might be overwritten in takeover)
pcnfsd.umask 22
ra.path_switch.threshold 100 (value might be overwritten in takeover)
raid.background_disk_fw_update.enable on (value might be overwritten in takeover)
raid.disk.copy.auto.enable on (value might be overwritten in takeover)
raid.disktype.enable off (value might be overwritten in takeover)
raid.max_fill_holes.size 0 (value might be overwritten in takeover)
raid.media_scrub.enable on (value might be overwritten in takeover)
raid.media_scrub.rate 600 (value might be overwritten in takeover)
raid.media_scrub.spares.enable on (value might be overwritten in takeover)
raid.min_spare_count 1 (value might be overwritten in takeover)
raid.mirror_read_plex_pref local (value might be overwritten in takeover)
raid.reconstruct.perf_impact medium (value might be overwritten in takeover)
raid.reconstruct.wafliron.enable on (value might be overwritten in takeover)
raid.resync.perf_impact medium (value might be overwritten in takeover)
raid.rpm.ata.enable off (value might be overwritten in takeover)
raid.rpm.fcal.enable on (value might be overwritten in takeover)
raid.scrub.duration 360
raid.scrub.enable on
raid.scrub.perf_impact low (value might be overwritten in takeover)
raid.scrub.schedule
raid.timeout 24 (value might be overwritten in takeover)
raid.verify.perf_impact low (value might be overwritten in takeover)
replication.logical.reserved_transfers 0 (value might be overwritten in takeover)
replication.logical.transfer_limits current (value might be overwritten in takeover)
replication.throttle.enable off
replication.throttle.incoming.max_kbs unlimited
replication.throttle.outgoing.max_kbs unlimited
replication.volume.reserved_transfers 0 (value might be overwritten in takeover)
replication.volume.transfer_limits current (value might be overwritten in takeover)
replication.volume.use_auto_resync off (value might be overwritten in takeover)
rmc.setup off (value might be overwritten in takeover)
rpc.mountd.tcp.port 4046
rpc.mountd.udp.port 4046
rpc.nlm.tcp.port 4045
rpc.nlm.udp.port 4045
rpc.nsm.tcp.port 4047
rpc.nsm.udp.port 4047
rpc.pcnfsd.tcp.port 4048
rpc.pcnfsd.udp.port 4048
rpc.rquotad.udp.port 4049
rquotad.enable on (value might be overwritten in takeover)
rsh.access legacy
rsh.enable on
security.admin.authentication internal
security.admin.nsswitchgroup
security.passwd.firstlogin.enable off
security.passwd.lockout.numtries 4294967295
security.passwd.rootaccess.enable on
security.passwd.rules.enable on
security.passwd.rules.everyone off
security.passwd.rules.history 0
security.passwd.rules.maximum 256
security.passwd.rules.minimum 8
security.passwd.rules.minimum.alphabetic 2
security.passwd.rules.minimum.digit 1
security.passwd.rules.minimum.symbol 0
sftp.auth_style mixed
sftp.bypass_traverse_checking off
sftp.dir_override
sftp.dir_restriction off
sftp.enable off
sftp.idle_timeout 900s (value might be overwritten in takeover)
sftp.locking none
sftp.log_enable on
sftp.log_filesize 512k
sftp.log_nfiles 6
sftp.max_connections 15 (value might be overwritten in takeover)
sftp.max_connections_threshold 75% (value might be overwritten in takeover)
sftp.override_client_permissions off
shelf.atfcx.auto.reset.enable auto (value might be overwritten in takeover)
shelf.esh4.auto.reset.enable auto (value might be overwritten in takeover)
shelf.fw.ndu.enable on (value might be overwritten in takeover)
sis.max_vfiler_active_ops 8 (value might be overwritten in takeover)
sis.min_share_blks 1 (value might be overwritten in takeover)
snaplock.autocommit_period none (value might be overwritten in takeover)
snaplock.compliance.write_verify off (value might be overwritten in takeover)
snaplock.log.default_retention 6m (value might be overwritten in takeover)
snaplock.log.maximum_size 10m (value might be overwritten in takeover)
snapmirror.access legacy
snapmirror.checkip.enable off
snapmirror.delayed_acks.enable on
snapmirror.enable on
snapmirror.log.enable on
snapmirror.readahead 0 (value might be overwritten in takeover)
snapmirror.readahead_freq 0 (value might be overwritten in takeover)
snapmirror.vbn_log_enable off (value might be overwritten in takeover)
snapvalidator.version 9
snapvault.access none
snapvault.enable off
snapvault.lockvault_log_volume
snapvault.nbu.archival_snap_default on
snapvault.ossv.compression off
snapvault.preservesnap off
snapvault.snapshot_for_dr_backup vsm_base_only
snmp.access legacy
snmp.enable on
ssh.access *
ssh.enable on
ssh.idle.timeout 600
ssh.passwd_auth.enable on
ssh.port 22
ssh.pubkey_auth.enable on
ssh1.enable off
ssh2.enable on
ssl.enable on
ssl.enable on
ssl.v2.enable on (same value required in local+partner)
ssl.v3.enable on (same value required in local+partner)
sslp.enable off
stats.archive.enable off
tape.reservations off (value might be overwritten in takeover)
telnet.access legacy (same value required in local+partner)
telnet.distinct.enable off (same value required in local+partner)
telnet.enable on (same value required in local+partner)
tftpd.enable off
tftpd.logging off
tftpd.max_connections 8 (value might be overwritten in takeover)
tftpd.rootdir /etc/tftpboot
timed.enable on (same value in local+partner recommended)
timed.log on (same value in local+partner recommended)
timed.max_skew 30m (same value in local+partner recommended)
timed.min_skew 0 (same value in local+partner recommended)
timed.proto ntp (same value in local+partner recommended)
timed.sched hourly (same value in local+partner recommended)
timed.servers 192.168.1.112 (same value in local+partner recommended)
timed.window 0s (same value in local+partner recommended)
tls.enable on (same value required in local+partner)
trusted.hosts * (same value required in local+partner)
vfiler.vol_clone_zapi_allow off
vif.failover.link_degraded off (value might be overwritten in takeover)
vol.copy.throttle 10 (value might be overwritten in takeover)
vol.snaprestore.nondisruptive off
wafl.default_nt_user
wafl.default_qtree_mode 0777
wafl.default_security_style ntfs
wafl.default_unix_user pcuser
wafl.group_cp off (same value required in local+partner)
wafl.inconsistent.asup_frequency.blks 10 (value might be overwritten in takeover)
wafl.inconsistent.asup_frequency.time 24h (value might be overwritten in takeover)
wafl.inconsistent.buf_limit 10
wafl.inconsistent.buf_not_fixable_limit 50
wafl.inconsistent.ems_suppress off (value might be overwritten in takeover)
wafl.inconsistent.ino_limit 5
wafl.inconsistent.snap_limit 5
wafl.maxdirsize 10470 (value might be overwritten in takeover)
wafl.nt_admin_priv_map_to_root off
wafl.root_only_chown on (value might be overwritten in takeover)
wafl.wcc_minutes_valid 20
webdav.enable off
Wish you all the best, thanks
0 REPLIES 0
