Network and Storage Protocols
Quotas for CIFS
stanleyj42
Is it possible to assign quotas to AD groups for CIFS shares?
We have a FAS3270 and are in th process of migrating our file server over to it and I am having trouble figuring how to take and AD group and assign the users say 300mb limits for the share.  Everything i have read leads me to believe it can be done but i have founding nothing showing how.  The netapp is joined to AD and i can add users and groups to the shares.  Just not the quotas.
1 ACCEPTED SOLUTION
peter_lehmann
It is not possible with the "built-in" quota functionality, there are 3rd party tools to help with (but $$$)...
You can use a "workaround" by creating a qtree per share and then set the tree-quota to the limit you want.
Hope this helps.
Peter
3 REPLIES 3
peter_lehmann
Hope this helps.
Peter
radek_kubka
Hi,
Have you seen this thread by any chance?
http://communities.netapp.com/message/8318#8318
Regards,
Radek
stanleyj42
thanks radek.  That post was excatly like my scenerio.  Unfortunatly it confirmed that i cannot use the netapp to place quotas on AD groups.
