Network and Storage Protocols
SRM and SnapMirror NFS datastores
mdvillanueva
Hi Experts,
We have SnapMirror relationships for all our NFS volumes(datastores) to our DR site. Now we have SRM. I know that NFS support is relatively new in SRM.
I am reading the SRM manual and it says this:
     "You must identify a datastore that SRM will use to store placehold virtual machines."
Is this separate from the SnapMirror volume that we can mount to our DR site's VM environment?
Does anyone have a good instructions for setting up SRM and Netapp NFS volumes(datastores)?
Thanks,
Maico
2 REPLIES 2
radek_kubka
Hi,
Datastore for placeholders should not be replicated - it is a local datastore at DR site only (you may need one at Primary as well if you reverse the protection relationship).
TR docs about SRM on NetApp:
http://www.netapp.com/templates/mediaView?m=tr-4064.pdf&cc=us&wid=151488945&mid=74783575 (SRM 5)
http://www.netapp.com/templates/mediaView?m=tr-3671.pdf&cc=us&wid=20624469&mid=8703229 (SRM 4)
Regards,
Radek
mdvillanueva
Thank you, I will check that out.
Maico
