Network and Storage Protocols
VIBE option "novmset" does not work
ulrik_ivers
Hi,
Trying to configure VIBE to backup our VMware ESX 3.5 environment.
Everything is working fine, except that I can't seem to get the "--novmset" option to work. The documentation states that this options should be used to exclude certain VMs from the backup. I'm reading this to mean that no VMware snapshots should be made of the VMs listed with this option.
I'm using the option "--dsset" to specify a datastore containing (at the moment) three VMs. I'm trying to exclude one or more with "--novmset" but ALL the VMs in the datastore are getting snapshoted anyway.
No error messages in the log, everything works fine, except that the "novmset" seems to be ignored.
Anyone have any ideas?
Here's the relevant lines from the .cfg-file that is used.
# VIBE Backup Configuration File
backup
dsset=vmDC01sys01FC:172.16.2.28
novmset=STOK00736DB01
cluster=Cluster01DC01
verbose
protocol=ssh
snapname=sv_man_nightly
reportdir="E:\Backup\VIBE"
Regards,
/Ulrik
1 ACCEPTED SOLUTION
rmatt
Hi, all.  I have a working fix for this that I plan to post to the ToolChest, but I'd like to get you to test it if you would before I release it to make sure it meets you needs.  Please send me a private message and I'll get the test application/installer of VIBE over to you.  Thanks,
--Matt
7 REPLIES 7
rmatt
Hi, Ulrik.  Can you attach the log so I can see what is happening?  The --verbose (and --debug if you can) output would be ideal.  Thanks,
--Matt
ulrik_ivers
Hi Matt,
I've finally have had the opportunity to test this again. I'd really appreciate a fix for this, as it is now I've had to create a separate NFS store for the VMs that I do not want to do a VMware snapshot of prior to taking the NetApp snapshot.
Attached are three logs.
log1.log: Verbose log when the "novmset" flag is NOT defined
log2.log: Verbose log when the "novmset" flag is defined as "novmset:STOPKIROOT"
log3.log: Same as log2 but with debug logging
Regards,
/Ulrik
byrondolan
I'm experiencing the same problem - novmset doesn't appear to work. Does it work for anyone?
Thanks,
Byron
rmatt
--Matt
stefan_bast
Hi all!
I've got the same problem with VIBE but I can't get it fixed ! Is there any fix or a workaround available to solve this problem?
Thanks in advance for your help!!
Stefan
ulrik_ivers
Hi,
Matt distributed a new version (1.0.12) that had the bug fixed so that novmset now works. The new version is not available yet on NOW what I can see (http://now.netapp.com/NOW/download/tools/vibe/).
If you send me an email I can send you the not official 1.0.12 version. I've benn running it in production several weeks.
/Ulrik
rmatt
Just a heads-up, wanted to update this thread and say --novmset modifications are now available on the NOW ToolChest, and 1.0.12 is available to everyone.  Thanks,
--Matt
