Network and Storage Protocols
WARNING: NFS: 898: RPC error 13 (RPC was aborted due to timeout)
vikash_roy
I am trying to mount NFS datastore on vSphare 4.0 from my netapp sim 7.3 version and I am getting following error message while mounting under vmkernel
WARNING: NFS: 898: RPC error 13 (RPC was aborted due to timeout) trying to get port for Mount Program (100005) Version (3) Protocol (TCP) on Server (10.1.101.124)
[root@xxx ~]# esxcfg-route
VMkernel default gateway is 10.4.100.1
[root@xxx ~]# vmkping -D
PING 10.4.100.140 (10.4.100.140): 56 data bytes
64 bytes from 10.4.100.140: icmp_seq=0 ttl=64 time=0.434 ms
64 bytes from 10.4.100.140: icmp_seq=1 ttl=64 time=0.049 ms
64 bytes from 10.4.100.140: icmp_seq=2 ttl=64 time=0.046 ms
--- 10.4.100.140 ping statistics ---
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 0.046/0.176/0.434 ms
PING 10.4.100.1 (10.4.100.1): 56 data bytes
64 bytes from 10.4.100.1: icmp_seq=0 ttl=255 time=0.999 ms
64 bytes from 10.4.100.1: icmp_seq=1 ttl=255 time=0.837 ms
64 bytes from 10.4.100.1: icmp_seq=2 ttl=255 time=0.763 ms
--- 10.4.100.1 ping statistics ---
round-trip min/avg/max = 0.763/0.866/0.999 ms
[root@xxx]# ping 10.1.101.124
PING 10.1.101.124 (10.1.101.124) 56(84) bytes of data.
64 bytes from 10.1.101.124: icmp_seq=1 ttl=254 time=0.507 ms
64 bytes from 10.1.101.124: icmp_seq=2 ttl=254 time=0.554 ms
64 bytes from 10.1.101.124: icmp_seq=3 ttl=254 time=0.644 ms
--- 10.1.101.124 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 1999ms
rtt min/avg/max/mdev = 0.507/0.568/0.644/0.060 ms
netappsim1> exportfs
/vol/vol0/home  -sec=sys,rw,nosuid
/vol/vol0       -sec=sys,rw,anon=0,nosuid
/vol/vol1       -sec=sys,rw,root=10.4.130.17
Can anyone provide me help what I might be doing wrong?
2 REPLIES 2
adamfox
You can try turning on the option nfs.mountd.trace and watch the console as you try to mount it and see if anything shows up.
This might give you a clue.
vikash_roy
I have solved it and update here all the detail
http://vikashkumarroy.blogspot.com/2009/12/rpc-error-13.html
In nutshell : vmkernel IP should be in subnet thats of NFS server.
Thanks,
Vikash
