Network and Storage Protocols
What the best for permission setting for NTFS Cifs Share
leongkoklow
For a pure NTFS qtree cifs share what is the best configuration: hence i share our way of sharing CIFS.
Filer:
ABC/Admin - Full Control
Everyone - Read Only
ABC/Engr - Change
ABC/User - Change
Windows NTFS SACL
ABC/Engr - Change
ABC/User - Change
Also, they are some engineer proposing to grant Everyone Full Control at Filer and control whatever permission set at Windows NTFS File Level.
Would this be an better options to grant everyone Full Control, is there any draback or overhead in term of performance.
Thx
1 ACCEPTED SOLUTION
adamfox
Everyone ~ Full Control at the share level isn't always a bad idea as long as you put proper controls on your files at the NTFS level. It avoids the issue of clashing permissions. But it really depends on what you are trying to accomplish. Share permissions can serve a good purpose if they accomplish what you want.
Just an opinion here.
6 REPLIES 6
BrendonHiggins
Everyone ~ Full control. Not on my box!
I remove the everyone group from each CIFS share once I have correctly configured the groups and permissions as required. Less is more when it comes to access control...
adamfox
scottgelb
It's always like Chevy vs. Ford when I have this conversation with customers. Whatever the customer is comfortable with ... we'll let you do what you want.. share vs. file ... I tend to see more everyone shares than not though in several years of working with NetApp at customers... and agree completely it is harder to troubleshoot when share and file permissions are fighting... One reason I can see locking down at the share is if Access Based Enumeration is or is going to be implemented.
reinoud7
This is perfect question for a poll
All our shares are full control. All the security is set on ntfs. Works great, is easy to maintain and very easy for trouble shooting. But indeed, you must choose the model that's fits your company (and your administrators )
leongkoklow
Thanks guy for sharing your thought with me, indeed it help me to understand more on how industry is handling CIFS.
Btw, ABE is not yet enable for our filer.
And most likely it will not be approve by L3.
I myself prefer the file-level locking to Share-level as it give more control and easy to troubleshoot.
cebulrdcis
my recommendations is that to aviod or please dont put everyone full cifs/netapp level permission on your filers specially when your filer is in a heterogenous environment with NFS & CIFS or a multiprotocol filer (uses CIFS and NFS).. you can read more on http://media.netapp.com/documents/wp_3014.pdf (chapters 3 & 4)
for me the better way to replace the everyone full permisison is with NT AUTHORITY\Authenticated Users probably with change permission not with full..then implement a Active Directory Domain User grouping and add the group in the CIFS Level permission and create another group for security level permission.
example,
CIFS/NetApp level permission
Filer01> cifs shares Test
Test /vol/v_vol01/test
ADDomain\test_ms / Change
ADDomain\test_rs / Read
In security level permssion
Test
-- ADDomain\test_ms -- with modify permission
-- ADDomain\test_ms-- with read& execute permission
this will make sure that only the users who are member in the group can access in the share drive Test.. this is also good when you have a security audit..
Regards,
tons
