Network and Storage Protocols
how to zero netstat statistics
INVESTSTROY15
I've changed network configuration and I need fresh statistics data.
There is ifstat -za for ifstat.
There is nfsstat -z for nfsstat.
But how do I clear netstat statistics for protocols (netstat -s)?
(man page doesn't have an answer.)
2 REPLIES 2
mharding
Did you try the '-z' or similar options?  May have been missed in the documentation. If that doesn't work and no one has responded in the meantime, then try Tech Support.  http://support.netapp.com/
INVESTSTROY15
There is no explicit or implicit -z key.
The support stated this app doesn't support zeroing.
