Network and Storage Protocols
igroup
sree_kanth787
we do igroup show to know the hosts in the igroup.now it lists both the fcp and iscsi hosts in the igroup.
now my question is  ->  for fcp they are the wwpns of hosts listed .if so what is for iscsi are they wwnn or wwpn or iscsi node?
4 REPLIES 4
shubhada
They are nodes. You can use igroup show -v <initiator_group> to list members of the particular group and get a verbose listing.
sree_kanth787
hey thankyou for ur kind reply,
but dude  why they are nodenames for iscsi as  they are port names in case of fcp? can u digg out more into this
netappnasadmin
iscsi is represented using iqn naming conventions,
amiller_1
The most precise answer is.....neither. iSCSI goes by what are called "iqns" -- something like "iqn.1998-01.com.vmware:esx10-3f9da30d". Great info on the format here....
http://en.wikipedia.org/wiki/ISCSI#Addressing
You can mix in CHAP as well for higher security (basically a single shared password).
