Network and Storage Protocols
netapp nfs mount permission denied
IVY_YANGXIAOHUA
I came across a nfs mount problem today;
/vol/fnd_git is a newly created volume....
filer01>exportfs -i -o  rw=10.74.XX.20,root=10.74.XX.20,nosuid /vol/fnd_git
filer01> exportfs
/vol/fnd_git    -sec=sys,rw=10.74.XX.20,root=10.74.XX.20,nosuid
[root@linux_client~]# cat /etc/redhat-release
CentOS release 5.5 (Final)
[root@linux_client~]# mount filer01:/vol/fnd_git  /test   ===>no problem here, can mount successfully
[root@linux_client~]# cd /test                                  ==========>but denied here
-bash: cd: /test: Permission denied
I even tried another 2 clients(one is solaris10 zone, the other is debian linux VM), and it is the same result :  can mount successfully,but permission denied if try to "cd" or "ls"
it's confusing
could it be psosible relate to networking issue – either firewall or nat’ing? I am not sure, if yes, how can I trouble shoot?
I am a newbie of Netapp....please help
1 ACCEPTED SOLUTION
pascalduk
What security style does the volume have? If it is ntfs, then ntfs permission could prevent user access.
You can check the security style with the "qtree status fnd_git" command.
6 REPLIES 6
pascalduk
IVY_YANGXIAOHUA
yes, it is indeed ntfs ,how could I change?
filer01> qtree status fnd_git
Volume   Tree     Style Oplocks  Status
fnd_git           ntfs  enabled  normal
filer01> options wafl.default_security_style
wafl.default_security_style  ntfs
IVY_YANGXIAOHUA
I read from the forum that currently there are no APIs available to set/change the security style of qtrees. and the  qtree-create API sets the security style of the qtree to the default value specified in the option wafl.default_security_style.
So should I set the fl.default_security_style to unix first then recreate the volume?
IVY_YANGXIAOHUA
hi, Pascal
thanks very much!
I destoryed the volume fnd_git and set wafl.default_security_style to unix
then I recreate the volume fnd_git, then this new volume inherits the security style to unix.......
now it work!  the linux server have access and write permission now!
pascalduk
There was not need to destroy the volume as you can change the security style online using the CLI by treating the volume like a qtree.
> qtree security /vol/fnd_gi unix
IVY_YANGXIAOHUA
okay, i thought I can not change the security attribute of qtree through CLI....I made a mistake....
since the volume is new and no data so I destoryed it yesterday...
thanks very much
