Network and Storage Protocols
netboot issue
ismopuuronen
Hello,
ontap upgrade issue, I was updating FAS2040HA from 7.3.2 to 8.0.3P2.
>software update -r for both filers,
A>cf takeover
A>cf giveback
(Now the B node is 8.0.3P2 and A node is still 7.3.2)
B>cf takeover -n
Doesen't work, because of cifs
>cifs terminate, no luck...
>halt -d, well, that worked...
but...
takeover didn't happened, and B node was trying to boot 7.3.2.
It didn't boot up, because "bad disk label"
I tried to boot_primary, boot_secondary and etc. from LOADER prompt, no luck, always 7.3.2.
I was able to do netboot, but i get this menu:
Please choose one of the following:
(1) Normal Boot.
(2) Boot without /etc/rc.
(3) Change password.
(4) Clean configuration and initialize all disks.
(5) Maintenance mode boot.
(6) Update flash from backup config.
(7) Install new software first.
(8) Reboot node.
Selection (1-8)?
At this point a normal boot will be prohibited.
first i just tried with option 2, it booted up as 8.0.3P2.
i tried to do >software update, it didn't work, >download, didn't work.
if i type >version, it shows me 8.0.3P2,
>version -b shows me nothing.
then i did cf takeover from B node, and services are up, but A node is still trying to boot up 7.3.2.
Should i choose (7) from that netboot menu, or what?
Br.
Ismo.
1 ACCEPTED SOLUTION
CCOLEMAN_
Type "set-defaults" hit enter
Then type "bye"
and please let me know if the problem continues
16 REPLIES 16
aborzenkov
Where have you got this “halt -d” from? It should have been just the “halt”. Have you used Upgrade advisor to generate procedure? Also standard documentation does not tell you to use “halt -d” either.
Netboot is not supported in 8.x beyond special menu, so I am not really sure what you get using 2 at this stage.
The best is now to call support. It could be as simple as tweaking some environment variables but could require some more actions. Reinstalling CF may work but I am not sure whether it is the only missing step in upgrade.
AGUMADAVALLI
goto the maintenance mode, select a unassigned nic, assign a IP which is in the same subnet of you laptop IP or use the cross-over cable.
Run the netboot cmd, run the software update command again and restart the filer. You should be good to go.
thank you,
AK G
ismopuuronen
Hi
Like i said, >halt didn't work and >cifs terminate either (Do you guys know any other way to break cifs sessions?)
There is open case to netapp, but no answer yet...
Yes, i was able to do netboot, but i was't sure which one to choose from the menu? Netboot article doesen't tell.
(1) Normal Boot.
(8) Reboot node.
Selection (1-8)?
Well, I guess it (7) now,
I found this manual Replacing a CompactFlash card in a FAS2040 system runnin Data ONTAP 8.0 7-Mode....
There is a section, where netboot is done, i think i should just follow those steps, but because i'm having open case, i'll wait netapps answer first
Br.
Ismo.
thibault
May I ask you if NetApp Support has provided you with the counsel needed?
And if not, May I ask you for the the case number?
Thanks,
JP
ismopuuronen
Hi,
Still open case.
Netapp gave me step by step instructions, but for some reason, it didn't boot up after ontap install and ended up to loader promt again.
Br.
Ismo.
thibault
Thanks,
JP
ismopuuronen
Hi,
I sent a private message to you.
Br.
Ismo.
ismopuuronen
Both nodes up and running 8.0.3P2.
I just had to do, few reboots manually. I'm not sure why, but maybe because there was ontap update at the same time in this case.
Just in case, i issued >software update command again. No errors, everything ok.
Then i issued cf takeover, the other node says during boot: autoboot fail.... and then i'm at loader promt again.
from there i can boot filer up using example bye. (autoboot fails)
Br.
Ismo.
CCOLEMAN_
can you type "printenv" at the loader prompt and post the results?
ismopuuronen
I sent a privet message to you.
Br.
Ismo.
CCOLEMAN_
Thanks, I just responded.
AGUMADAVALLI
use the netboot and reinstall the software, you should be fine.
If not, I think you need professional services support.
thank you,
AK G
ismopuuronen
So i need professional help then.
There is open case to netapp, but no solution yet.
Br.
Ismo.
CCOLEMAN_
Then type "bye"
CCOLEMAN_
type those commands at the loader prompt
ismopuuronen
Hi,
Thank you for your response.
I don't have an experience about content in >printenv
But i was thinkin to se the defaults, I just didn't had courage to do that on my own
Case will continue next week, so you have to wait
But i'll also wait netapps response for this, and their opinion about to use >set-defaults >bye commands.
Thank you!
Br.
Ismo.
