Network and Storage Protocols
second-level interface group
chinchillaking
Hi All,
Refer NetWork Managment Guide, second level interface group - "You can create a second-level interface group by using two multimode interface groups".
Could it create first two port with lacp, and second one port with single model, and then create second level interface group combine before two group?
ifgrp create lacp first -b ip e0b e0a
ifgrp create single second e0d
ifgrp create single Secondlevel first second
Best regards,
Chung
1 ACCEPTED SOLUTION
aborzenkov
Yes, that's possible, but there is no real reason to have second VIF at all - you can just as well have single mode VIF between multi mode VIF and physical interface.
1 REPLY 1
aborzenkov
