ONTAP Hardware
0Byte ISCSI LUNS on an FAS2554
WinstonWolf
Hello ,
I create some ISCSI LUNS on an FAS2554 .
All the Luns are ISCSI Drives on an W2008R2 Windows Server .
But two LUNS shows in the FAS Admin Console something strange .
The Free Place from the Lun shows 0Bytes and an 100% Usage of this LUN . but in Windows the Drive is only half Full
The other LUNs shws the correct values .
When i try to reduce the Size of this strange two ISCSI Drives in Windows , the Windows Harddisk Manager hangs up .
Can someone help me .
Thanks
Michael
4 REPLIES 4
Renifa
Hi WinstonWolf,
One possibility is that when Host deleted files on the DISK , the auto re-claim on the Storage LUN (Thin-Provisioned) did not happen. If Space Allocation is set to disable than Data ONTAP does not reclaim space automatically when your host deletes data. Verify that space allocation is enabled: lun show -vserver vserver_name -volume volume_name -lun lun_name –fields space-allocation
Hope this helps.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
WinstonWolf
Thanks, im no netapp specialist, what you mean with : : lun show -vserver vserver_name -volume volume_name -lun lun_name –fields space-allocation ?
The ISCSI Luns in Windows are used for Veeam Backup Repositorys. Veeam Backup the VMs and write Full Backup and incremental Backup Files in this Drives.
All ISCSI LUNs are configured with the same Settings.
Can i find the Space Allocation Option in Control Manager too ?
WinstonWolf
What is a Vserver ? Where i can find the Vserver Name in my FAS 2554 ?
Thanks
WinstonWolf
The LUNS are Thick Provisioned . I think the Data Alocation Option is only for Thin Provisioned LUNS .
What can be the Reason , Here an Screenshot from read out the Log Files .
It looks like the LUNS are fuller then there total Size ?!?!?!
The Windows Drives are used for Backup Target for Veeam Backup , that writes Files in this Drives which was overwrite at a special Time .
In Windows Operating System the Drives are at the Moment half Full .
No One has an answer ?
Thanks
Michael
