ONTAP Hardware
111-00585 and 111-00586 the difference?
Cornish
Hello,
Does anyone know the differences between 111-00585 and 111-00586, as I  have the “6” version and says it is not compatible.
I don't understand why.
I am looking for a FAS 3210 controller board.
thanks for any help 🙂
1 ACCEPTED SOLUTION
darb0505
Hi Cornish,
The difference between 111-00585 and 111-00586 is that the 111-00586 is the part number that we used for a PCM (motherboard) replacement.  The 111-00585 was used for a full headswap that would come with memory and boot media.
If you are looking for a replacement PCM then look at the 111-00586 which is the part used for a standard motherboard replacement.
Hope that helps.  Let me know if you have any additional questions.
Thanks
Team NetApp
1 REPLY 1
darb0505
Hi Cornish,
Thanks
Team NetApp
