ONTAP Hardware
2 x FAS8040 single in the same Enclosure. one running ONTAP 9 another running ONTAP 7-mode 8.2.5
Rogerio_Ivo
Hi friends.
I´d like to know if the following scenario is possible:
I have a single chassis with 2 FAS8040 working as HA Pair running ONTAP 7-mode 8.2.5
The intention is to migrate to ONTAP 9, with additional disks, but using one of the FAS8040 CPU´s.
To accomplish that, I´d remove one CPU from the 7-mode HA-pair. Lets call this CPU as "CPU-B".
So, at this time, CPU-A serves all data on the 7-mode environment. CPU-B is disconected, both in the same chassis.
Disconnect all cables connected to CPU-B. Recable CPU-A to single
Modify the ha-config parameter on chassis to non-ha, if necessary (will be necessary to enter in maintenance mode)
At this point both CPU´s are isolated each other, but in the same chassis.
Then I install ONTAP 9 on CPU-B with new shelves bought by customer. Cable the shelves and install the ONTAP as a single cluster.
Then I start copying the data from 7-mode CPU to Cluster CPU (using 7MTT or any other method).
When finished, reformat the CPU-A with ONTAP 9 and join it into Cluster CPU-B to restabilish the HA-Pair in C-mode.
Anyone knows if this is possible? Or maybe some similar procedure?
Thanks in advance,
Roger Ivo
1 REPLY 1
SpindleNinja
In the same HA pair, i'm going to say, no.
There's a copy-free transition which is kinda like what you described but requires new heads and not really for the faint of heart IMHO.     - https://docs.netapp.com/ontap-9/topic/com.netapp.doc.dot-7mtt-cft/GUID-85E96D13-B32F-4445-B658-7C7D0AA3997E.html
I've done this conversion before for customers, and we got swing gear (heads, disks and switches).
Went something like this ->
Deploy loner heads as cluster as a switched cluster.
Migrate to it.
convert FAS8xxx to ONTAP (cdot)
Join it to the existing cluster.
vol move data over.
remove/decom loaner gear.
convert to switchless cluster.
