ONTAP Hardware
7-Mode and cDOT in the same SAN Switch
ADDEDMARIORF3
Hello Team,
I Can configure in the same switch Brocade 300 ports with Storage NetApp 7-Mode and cDOT since i need enable NPIV in the Switch ?
Thank you !
-MRF
1 REPLY 1
mikkisse
Hello!
Yes, you need to enable NPIV for NetApp cDOT.
"Clustered Data ONTAP uses NPIV to present Fibre Channel targets to a fabric. Make sure to use an NPIV-capable switch and to enable NPIV functionality. For details on which environments are supported, see the online NetApp Interoperability Matrix."
And think there is no problems to connect cDOT and 7 mode NetApp to same SAN switch.
