ONTAP Hardware
A300 disk shelf move
Ramachandra_P
A300 have 4*DS224C(shelf ID 0,1,2,3)  in single stack. Data aggregates are spread among all disks in this stack. During maintenance window, I plan to move the shelf id 3 to a new stack within the same A300, set new shelf ID as 10 and power on shelf and controller.
Does it cause any impact to data?
Is there any document or KB for this?
2 REPLIES 2
cedric_renauld
Hello
You can do it, all disk are "tagged" and can move to another shelf or alos change ID
At the reboot the Ontap retrive all tags and retreive all data
weiliu
Hello.
 In normal cases, data is not affected. You need to check whether the SAS link is normal and whether the disk array to be removed has disks in the raid group.
You may refer to the website
Hot-remove a shelf - shelves with IOM12/IOM12B modules (netapp.com)
