ONTAP Hardware
AD integration in 7 mode and C mode
lachu
Hello Team,
I have both 7 mode and C mode in my environment. I need to do the AD integration of my controllers. Can anybody help me with the steps for the same.
3 REPLIES 3
GidonMarcus
Hi
can you confirm the:
1. OS version (i think that in Cdot 8.3 they changed the methood)
2. if you have CIFS licenced
3. if CIFS already in use on the same domain?
if already have them you likelly have very few steps to go forward. if not - you likelly need to complete some pre-requist depand on the situation.
Gidi.
Gidi Marcus (Linkedin) - Storage and Microsoft technologies consultant - Hydro IT LTD - UK
lachu
OS Version is 8.3.1.
CIFS is licensed.
CIFS not in use in domain
GidonMarcus
that's the tricky bit:
As you don't have CIFS and enabling it might not be straight forward (main consideration is if your network connectivity is ready. and a  extra use of CPU resources).. i would have just use the LDAP functionality and not the AD CIFS integration:
https://library.netapp.com/ecmdocs/ECMLP2348035/html/GUID-725D9074-9A70-437C-A348-7281DF12E5AD.html  for Cdot
https://library.netapp.com/ecmdocs/ECMP1155684/html/GUID-8BE8ADEB-466A-4838-A27D-BB213661BF59.html  for 7 mode
if you had a CIFS configured. you would have only need to run the following on the Cdot
     security login domain-tunnel create -vserver <your CIFS SVM>
and start using it with:
     security login create -user-or-group-name domain\group -application ontapi -authmethod domain -role admin
     security login create -user-or-group-name domain\group-application http -authmethod domain -role admin
and the following on the 7-mode:
useradmin domainuser add domain\group -g administrators
if you think it's straight forward for you to create CIFS SVM and add the 7-mode to a domain - do it and complete the above, it will be also more secure then LDAP (as it will use Kerberos or NTLM. and not send the password over as LDAP do)
