ONTAP Hardware
AT-FCX
TKNODELL1
Working on doing a shelf firmware upgrade -- https://support.netapp.com/NOW/cgi-bin/shelffwdnld.cgi/download/tools/diskshelf/bin/IOM3.0172.SFW
I don't think I have the AT-FCX module but I'm not 100% sure. How can I tell? Is there specific output in sysconfig -a that I should look for?
1 ACCEPTED SOLUTION
JGPSHNTAP
What type of filer do you have.  Also, if you have at-fcx you will see something like
Shelf 1: AT-FCX  Firmware rev. AT-FCX A: 38  AT-FCX B: 38
3 REPLIES 3
JGPSHNTAP
TKNODELL1
It's a FAS3240 w/ DS4323 shelves.
I do not see any reference to AT-FCX in sysconfig -a at all -- so I'm going to go ahead & say I don't have it. Thanks for the clarification!
JGPSHNTAP
AT-FCX are super old.. You're good to go
