ONTAP Hardware
Adding shelf to an existing aggregate
brasbehlph
I am trying to add a shelf of 14 disks to the following configuration.
Fas2020 single head
#base unit 300 15k Sata
volume aggr0 (1 RAID group):
         group 0: 11 disks
#shelf1 500GB 7,2k Sata
volume aggr1 (1 RAID group):
         group 0: 14 disks
I would like to add more spindles to aggr1 but when testing adding 5 disks I get the following error message.
"not all disks used; a raid_db raid group must have at least 3 disks netapp"
I imagine the default raid size of 16 is causing this error.
What option would be best? Are these the only options?
1. Add aggr2 for the entire shelf with its on raid group
2. Add all disks to aggr1 and let it configure the second raid group on aggr1
Thanks in advance
1 ACCEPTED SOLUTION
peter_lehmann
It depends if these disks you wnat to add are the same as the 14 disks already in aggr1...
I'd add them to aggr1, but first set the raidgroup size to 1, then you'll get a bigger aggr1 with 2 RG's each of 14 disks.
But also keep in mind to have "enough" sparedisks !
Peter
6 REPLIES 6
peter_lehmann
Peter
radek_kubka
You mean 14? (just double-checking )
peter_lehmann
Yes... 14 !
thanks
brasbehlph
Sounds great, I will get this applied after hours tonight.
I think I can use the following command to change the raidsize to 14.
>aggr options aggr1 raidsize 14
Next I will try to add disks to aggr1 assigning it to a new raid group (rg1)
>aggr add aggr1 -g rg1 -d disk_list
Is it not possible to do these command through "NetApp System Manager"?
thanks
radek_kubka
I haven't played a lot with System Manager 2.0, but I don't think this is doable via GUI.
brasbehlph
Worked perfectly but I had to change the second command.
After changing the raidsize to 14:
aggr options aggr1 raidsize14
I had to let the filer create the new raid group:
aggr add aggr 12@413
My old aggr1 now contains two raid group.
volume aggr1 (2 RAID groups):
        group 1: 12 disks
        group 0: 14 disks
Thanks all for the help.
