ONTAP Hardware
BSAS and SATA
RATNATHURAI
I have fas2040 with internal disks , the oncomand sytemMAnager shows as BSAS,
Can I mix these disk with SATA for an aggregate?
both disk are same size and same speed.
3 REPLIES 3
martin_fisher
BSAS are SAS disks in a SATA enclosure/shelf.
You cannot mixed SAS and SATA together and its certainly not recommended. best practise is create aggr's for each disk type where possible. I would keep then separate.
RATNATHURAI
I read BSAS are SATA disk on a SAS enclosure
https://communities.netapp.com/thread/13084
BALAJI_VENKATRAMAN
You are correct - BSAS is similar to SATA and can be used for Tier 2 storage in general applications.
The various types of mix and match is available in below link
https://library.netapp.com/ecmdocs/ECMM1277794/html/smg/GUID-2F317E55-FBC5-46A1-B121-215861E1258A.html.
Also read more about it in TR-3437
Balaji
