ONTAP Hardware
Backing up Initiator Groups
jmmorrell
Is there a way to backup the initiator groups on a controller? Are they stored in a particular file?
I will be migrating from a FAS3140 to FAS3170. We are not migrating the root volume from the FAS3140 to FAS3170. Is there a way to export/import?
Thanks,
Jim
1 REPLY 1
ekashpureff
Jim -
What an interesting question. It's one I haven't been able to find the answer to !
They've got to be stored somewhere, but I can't find a file changing as I create/destroy an igroup on my sim, nor can I grep the igroup from any files.
Best suggestion for a backup would be to write up a script to parse out an 'igroup show' command output.
I hope this response has been helpful to you.
At your service,
Eugene E. Kashpureff
[email protected]
NetApp Instructor and Independent Consultant
http://www.linkedin.com/in/eugenekashpureff
(P.S. I appreciate points for helpful or correct answers.)
