ONTAP Hardware
Basic Question on FAS2020
jkoelker01
how can one tell how much ram is installed on my fas2020 and also how much built in cache is on the filer? I also know there is one cpu in it but what is the speed of it? Trying to find commands or something to tell me this.
1 ACCEPTED SOLUTION
ralfaro01zero
Type sysconfig -a on your filer's shell, it'll give you the information.
As default the FAS2020 comes with 1024MB of system memory and 128MB of NVRAM per controller, the processor is an Intel Celeron, I believe it is 2Ghz.
Cheers.
3 REPLIES 3
ralfaro01zero
Cheers.
jkoelker01
Thanks for the quick response. That was exactly what I was looking for.
radek_kubka
I believe NVRAM on 2020 uses part of system memory, so basically eats up into this 1GB.
I've never seen any official spec, but Wikipedia says 2020 has 2.2 GHz Mobile Celeron (http://en.wikipedia.org/wiki/NetApp_filer)
Regards,
Radek
