ONTAP Hardware
Breath Life Into FAS3020
sunking
Good evening,
I have been tasked with getting an old decommissioned FAS3020 stood back up and running. We would like to factory reset it and basically start over with the array. I have been looking for documentation on the FAS3020 and I cannot seem to find anything. Can anyone point me to the FAS3020 documentation or provide some hints in how I would be proceed in this task.
Thank you all in advance...
3 REPLIES 3
Flane_Schlueter
Hi,
connect with a serial cable to the filer,
power on the system
when ONTAP is booting "press ctrl + c"
now you come in the Mainanance Mode
(1) Normal boot.
(2) Boot without /etc/rc.
(3) Change password.
(4) Initialize all disks.
(4a) Same as option 4, but create a flexible root volume.
(5) Maintenance mode boot.
Selection (1-5)? 4
press option 4!
follow instructions
i meen  Y, Y
an you became many points on your display.
initialize all disk is finished the FAS running in the setup.
have fun
Dirk
sunking
Thanks Dirk!!! I appreicate the response. Is there a link to documentation for the 3020? Not seeming to find anything...
andris
FAS3020 support ended about 4-1/2 years ago.
You might be able to find guides on the Internet - try searching for "FAS3000 series".
We still have the installation and setup guide posted:
https://library.netapp.com/ecm/ecm_get_file/ECMM1280261
The ONTAP 7.3 Documentation Roadmap can help you with documentation titles that you might want to find...
https://library.netapp.com/ecm/ecm_get_file/ECMM1278403
ONTAP 7.3.7P1 would be the last valid release for you to run. There is some archived documentation available:
7.3.7 (NetApp Storage Systems) All documents
Release Notes ( HTML , Acrobat )
