ONTAP Hardware
CISCO SFP on FAS2050
acistmedical
I have a FAS2050, it has 4 ZFC ports in the back (2 per controller) that are empty.
Do i have to get NetApp branded SFP transceivers, or can i just stick CISCO ones i have on hand, these are brand new 4Gb FC SFP, LC connectors.
Thanks
2 REPLIES 2
reinoud7
Very good question, but I don't know. We had in the past the opposite problem, and we used NetApp SFP's in cisco's. That works, but to be sure, we have replace them afterwards.
It's a pity that we can't virtualize SFP's, otherwise I would P2V you some of mine. For some raison, I have now a dozen of spare NetApp SFP's.
Reinoud
John-CG
I have both Cisco's 4g sfp and genuine Netapp's 4g sfp. And I have fas 2020 in my lab. I have all the hardware disks/optics setup ready to perform the experiment. The only thing missing is the ontap operating system because I bought the fas 2020 from a liquidator. I wish I can help and get help perform the sfp swap test.
