ONTAP Hardware
CPU High Usage On my filer FAS2040 A-A
NAYABRASOOL
Hi Experts,
We are getting CPU usage high alerts on our filers very often , don't know the reason why can anybody help me to trace this out.
Thanks,
Nayab
1 ACCEPTED SOLUTION
radek_kubka
Hi Nayab,
Some of the links are within partner area, so I believe your NOW account is end-user one, hence you cannot access it.
You can find reallocate manual here though on p. 480:
https://library.netapp.com/ecm/ecm_get_file/ECMP1120818
When you run reallocate measure you should get an output at the end specifying the level of fragmentation. If you didn't notice that, the previous check is saved and may be viewed by running reallocate status, rather than running reallocate measure once again.
As per the doc quoted above:
"The threshold when a LUN, file or volume is considered unoptimized enough that a reallocation should be performed is given as a number from 3 (moderately optimized) to 10 (very unoptimized)."
regards,
Radek
18 REPLIES 18
thomas_glodde
your filer generates performance stats in /vol/vol0/etc/stats/archive.
you can analyze these with CMPG from tech.netapp.com and see what causes the high cpu.
besides that, high i/o (backup) causes high cpu or deduplication, there might just be serveral regular scheduled processes which will cause these alerts.
NAYABRASOOL
It says my company doesnt have the Technet Access What do i need for this case open a case to Netapp , As i think this is nt technical related
radek_kubka
If you roughly know when these CPU spikes occur, try running "sysstat -x -i 2" from CLI (for few minutes) & post the output here.
NAYABRASOOL
Sure i will run this command next time wen i see the CPU high usage and paste it here
NAYABRASOOL
Hi Radek,
Please find the output of sysstat ran while the CPU high usage. Please examine and come back with your findings.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.12.11 04:35:52 =~=~=~=~=~=~=~=~=~=~=~=
sysstat -x -i 2
CPU   NFS  CIFS  HTTP   Total    Net kB/s   Disk kB/s     Tape kB/s Cache Cache  CP   CP Disk    FCP iSCSI   FCP  kB/s iSCSI  kB/s
                                  in   out   read  write  read write   age   hit time  ty util                 in   out    in   out
94%     0     0     0     833 29487 163131 169393  49187     0     0     4s  79%  98%  Fv  67%      0   833     0     0 27400 154742
95%     0     0     0     851 32369 174080 181847  29641     0     0    21s  81%  55%  Ff  46%      0   851     0     0 29985 167789
90%     0     0     0     790 27104 175319 175024  43761     0     0     4s  81%  53%  Ff  60%      0   790     0     0 24924 166186
84%     0     0     0     846 26189 185390 190786  10048     0     0    20s  74%  19%  Fn  57%      0   846     0     0 23994 175403
94%     0     0     0     819 34633 169097 176722  46230     0     0    21s  79%  96%  Fn  74%      0   819     0     0 32189 166085
91%     0     0     0     827 35876 160273 167275  57606     0     0     4s  80%  72%  Fs  58%      0   827     0     0 33600 153043
87%     0     0     0     728 36142 156081 155181  37494     0     0     4s  80%  45%  Fs  57%      0   728     0     0 33816 148504
92%     0     0     0     742 33521 155506 164628  34876     0     0     4s  77%  60%  Fs  77%      0   742     0     0 31043 149979
88%     0     0     0     802 36463 159385 168933  35658     0     0    23s  77%  69%  Ff  69%      0   802     0     0 34153 149001
94%     0     0     0     850 39564 160872 173439  48747     0     0    24s  78%  88%  Ff  58%      0   850     0     0 36953 153869
89%     0     0     0     813 33763 153363 163810  51213     0     0    24s  95%  71%  F   58%      0   813     0     0 31484 147822
90%     0     0     0     737 31241 153209 178475  38918     0     0    26s  74%  51%  F   74%      0   737     0     0 29001 143568
92%     0     0     0     832 32811 156456 189095  33544     0     0     4s  72%  55%  Ff  71%      0   832     0     0 30544 151044
90%     0     0     0     919 29704 155161 191770  33898     0     0     4s  69%  56%  Ff  90%      0   919     0     0 27592 146584
88%     0     0     0     889 28365 166607 192448  19928     0     0    24s  72%  49%  Fs  81%      0   889     0     0 26306 159095
86%     0     0     0     889 24806 180436 192052  30809     0     0    24s  78%  60%  :   66%      0   889     0     0 22770 173101
89%     0     0     0     889 26213 177119 199654  25448     0     0    24s  75%  68%  Ff  62%      0   889     0     0 24048 168977
88%     0     0     0     767 27308 163938 176072  42767     0     0     4s  79%  80%  Ff  53%      0   767     0     0 25247 161691
75%     0     0     0     837 22196 193263 182537   8279     0     0     3s  76%  19%  :   33%      0   837     0     0 20180 184292
87%     0     0     0     800 25309 184739 182144  37285     0     0     3s  79%  98%  Ff  44%      0   800     0     0 23023 174258
85%     0     0     0     921 16065 189620 200236  26556     0     0     2s  72%  65%  Ff  53%      0   921     0     0 14234 179540
82%     0     0     0     881 18340 188290 203049  18173     0     0    29s  78%  62%  :   63%      0   881     0     0 16473 180674
84%     0     0     0     801 23956 183288 180842  23364     0     0    30s  78%  59%  Ff  48%      0   801     0     0 21922 174959
90%     0     0     0     821 31642 164519 177063  39262     0     0    29s  76%  90%  Ff  50%      0   821     0     0 29309 158726
90%     0     0     0     743 35326 157521 151368  56048     0     0     2s  80%  84%  Ff  55%      0   743     0     0 33035 148262
89%     0     0     0     840 34210 178018 176172  30776     0     0     2s  78%  52%  Ff  42%      0   840     0     0 31712 170302
92%     0     0     0     858 37348 159177 176004  50516     0     0    28s  77%  88%  Ff  51%      0   858     0     0 34858 154288
88%     0     0     0     828 28140 178836 184174  28408     0     0     2s  78%  50%  Ff  62%      0   828     0     0 25925 169245
91%     0     0     0     883 31674 161892 188590  36074     0     0    29s  71%  64%  Fs  73%      0   883     0     0 29460 155008
92%     0     0     0     849 29564 163945 190967  28286     0     0    30s  74%  60%  Fs  82%      0   849     0     0 27434 155345
89%     0     0     0     924 20700 176983 206250  30056     0     0    28s  69%  65%  :   88%      0   924     0     0 18899 167445
81%     0     0     0     900 15719 160016 199039  13944     0     0     2s  66%  28%  Ff  85%      0   900     0     0 14271 152456
83%     0     0     0     925 17613 168362 200204  23970     0     0    28s  68%  99%  :   88%      0   925     0     0 16022 161162
83%     0     0     0     907 15710 173101 200745  15195     0     0    27s  68%  21%  Ff  83%      0   907     0     0 14147 167292
87%     0     0     0     935 25650 173438 202735  22536     0     0    26s  70%  86%  :   88%      0   935     0     0 23661 163762
89%     0     0     0     896 24912 170308 194223  26021     0     0    26s  72%  77%  Ff  81%      0   896     0     0 22965 164970
87%     0     0     0     879 18926 178244 199172  22980     0     0    24s  74%  66%  Ff  85%      0   879     0     0 17254 170451
88%     0     0     0     956 23377 176897 207166  26955     0     0     2s  70% 100%  :v  84%      0   956     0     0 21571 169426
86%     0     0     0     871 18881 184656 199318  22249     0     0    21s  75%  67%  Ff  68%      0   871     0     0 16880 177667
81%     0     0     0     854 14997 195666 200320  16440     0     0    21s  77%  58%  :   67%      0   854     0     0 13193 188974
85%     0     0     0     867 14996 183728 196143  16131     0     0    22s  77%  38%  Ff  66%      0   867     0     0 13236 176138
82%     0     0     0     791 19025 192277 181796  22885     0     0    21s  80%  82%  :   61%      0   791     0     0 17188 180339
82%     0     0     0     827 16781 173162 196941  12429     0     0    21s  75%  36%  Fs  59%      0   827     0     0 15148 168916
87%     0     0     0     871 21585 186578 186979  30439     0     0     4s  78%  93%  :   61%      0   871     0     0 19583 179288
88%     0     0     0     807 16823 181026 187694  24950     0     0     4s  76%  71%  Ff  78%      0   807     0     0 15006 169878
84%     0     0     0     943 23454 179213 200503  17040     0     0    21s  71%  57%  :   81%      0   943     0     0 21532 173574
86%     0     0     0     825 17159 173218 188563  32599     0     0    21s  76%  93%  Ff  79%      0   825     0     0 15496 164470
86%     0     0     0     881 25994 171880 189612  22633     0     0    21s  73%  64%  Ff  74%      0   881     0     0 23970 162964
86%     0     0     0     960 23653 175455 203080  24710     0     0    21s  71%  74%  :   89%      0   960     0     0 21676 169204
90%     0     0     0     936 24107 168213 200169  34476     0     0    21s  69%  92%  Ff  80%      0   936     0     0 22198 161771
87%     0     0     0     781 27269 172103 168688  41529     0     0    21s  76%  75%  Ff  61%      0   781     0     0 25207 163722
84%     0     0     0     888 21901 184556 197913   5357     0     0    21s  73%  20%  Fs  68%      0   888     0     0 19899 175918
85%     0     0     0     845 25202 175205 191620  33163     0     0     4s  74% 100%  :v  68%      0   845     0     0 23207 166193
86%     0     0     0     900 20851 183182 197532  25796     0     0     4s  73%  64%  Ff  61%      0   900     0     0 18956 177661
79%     0     0     0     861 19892 195889 196256  12024     0     0    20s  76%  45%  :   48%      0   861     0     0 17982 189402
85%     0     0     0     847 24883 179135 180048  34832     0     0    21s  77%  96%  Ff  44%      0   847     0     0 22810 171582
88%     0     0     0     767 20801 173437 177765  42040     0     0    21s  79%  82%  Ff  58%      0   767     0     0 18923 165477
84%     0     0     0     837 25288 188784 183249  12716     0     0     4s  78%  21%  Fn  45%      0   837     0     0 23089 179012
88%     0     0     0     771 32656 175075 173646  32197     0     0     4s  78%  65%  Fn  47%      0   771     0     0 30298 167672
84%     0     0     0     798 19982 179820 183013  41545     0     0    22s  76%  64%  :   55%      0   798     0     0 18144 171061
89%     0     0     0     981 30300 171567 195885  22465     0     0    22s  72%  52%  Ff  75%      0   981     0     0 28174 163917
90%     0     0     0     818 27002 164417 175687  50167     0     0    22s  76%  94%  Ff  64%      0   818     0     0 24938 162364
75%     0     0     0     822 25021 188326 173765   3229     0     0    23s  78%  11%  Fn  49%      0   822     0     0 22919 175682
90%     0     0     0     768 24742 172555 178900  38144     0     0     4s  77% 100%  :f  60%      0   768     0     0 22687 164579
85%     0     0     0     751 30570 164012 162120  32831     0     0     3s  79%  82%  Ff  50%      0   751     0     0 28327 160337
87%     0     0     0     833 23559 173984 180072  48204     0     0     3s  76%  63%  Ff  63%      0   833     0     0 21520 162849
80%     0     0     0     893 21172 189017 196848   5765     0     0     2s  78%  12%  :   61%      0   893     0     0 19159 179434
91%     0     0     0     840 26210 169094 195946  33677     0     0    30s  72%  89%  Ff  75%      0   840     0     0 24131 165641
90%     0     0     0     818 25326 179536 180284  29691     0     0     2s  80%  79%  Ff  69%      0   818     0     0 23271 168908
85%     0     0     0     884 20194 183964 192285  12581     0     0    30s  73%  63%  Fn  87%      0   884     0     0 18333 175926
90%     0     0     0     862 22770 172605 180398  38574     0     0    30s  73% 100%  :f  81%      0   862     0     0 20850 165757
92%     0     0     0     814 39067 165311 165196  41429     0     0    31s  81%  78%  F   72%      0   814     0     0 36499 159260
91%     0     0     0     820 33661 176880 171316  37991     0     0    32s  81%  59%  F   77%      0   820     0     0 31215 164836
87%     0     0     0     827 15323 181656 190416  37961     0     0     2s  77%  63%  F   81%      0   827     0     0 13564 176306
83%     0     0     0     921 18241 202275 197463     16     0     0    32s  75%   0%  -   79%      0   921     0     0 16257 192366
86%     0     0     0     875 19226 184037 195319  19421     0     0    31s  76%  62%  Ff  77%      0   875     0     0 17355 177111
81%     0     0     0     829 17461 192725 193249  18238     0     0    31s  76%  75%  :   63%      0   829     0     0 15621 183670
87%     0     0     0     818 19408 177697 184636  25913     0     0    31s  79%  65%  Ff  71%      0   818     0     0 17489 173005
82%     0     0     0     880 17456 194789 193656  13438     0     0    31s  76%  61%  :   66%      0   880     0     0 15526 186439
83%     0     0     0     767 13197 181597 176992  25083     0     0    31s  79%  61%  Ff  73%      0   767     0     0 11689 168407
86%     0     0     0     918 19129 182517 201161  17219     0     0    30s  74%  66%  :   82%      0   918     0     0 17335 179779
84%     0     0     0     826 15252 183049 196582  13543     0     0    28s  73%  39%  Fs  72%      0   826     0     0 13616 174730
87%     0     0     0     872 23593 184976 193461  29237     0     0    27s  76%  92%  :   74%      0   872     0     0 21495 175298
87%     0     0     0     877 24340 177082 191906  32517     0     0    26s  73%  83%  Ff  59%      0   877     0     0 22243 171684
83%     0     0     0     807 22150 187380 183418  20102     0     0    25s  76%  53%  Ff  41%      0   807     0     0 20130 176834
85%     0     0     0     915 27308 176052 187532  24440     0     0    24s  76%  80%  Fn  54%      0   915     0     0 25264 167940
88%     0     0     0     754 17994 167813 184229  37596     0     0    23s  78%  33%  :   71%      0   754     0     0 16275 163808
84%     0     0     0     836 21592 183280 188976  16192     0     0    23s  78%  39%  Fs  56%      0   836     0     0 19580 173128
87%     0     0     0     905 26434 181813 196398  27346     0     0    22s  76%  96%  :   62%      0   905     0     0 24266 174635
82%     0     0     0     799 14414 186416 188784  30540     0     0     4s  78%  91%  Ff  55%      0   799     0     0 12726 177814
79%     0     0     0     898 16763 193423 204986   7247     0     0     4s  77%  24%  :   45%      0   898     0     0 14886 185852
86%     0     0     0     805 16273 186486 191531  19591     0     0    22s  78%  74%  Ff  59%      0   805     0     0 14489 179463
82%     0     0     0     879 21642 191245 191344  21061     0     0    22s  77%  75%  :   53%      0   879     0     0 19590 182097
84%     0     0     0     819 13437 185834 189193  30322     0     0    22s  79%  87%  Ff  57%      0   819     0     0 11767 178732
80%     0     0     0     814 18796 199616 190956   8763     0     0     4s  80%  28%  :   46%      0   814     0     0 16921 190973
84%     0     0     0     795 18644 167421 179924  28211     0     0    24s  78%  81%  Ff  68%      0   795     0     0 16824 161397
81%     0     0     0     807 20091 193973 193045  12042     0     0    24s  81%  44%  :   64%      0   807     0     0 18100 184072
87%     0     0     0     823 21819 181742 188895  28941     0     0    24s  79%  86%  Ff  72%      0   823     0     0 19814 172772
89%     0     0     0     831 25890 175304 178655  37471     0     0    25s  80%  81%  Ff  73%      0   831     0     0 23814 168065
82%     0     0     0     823 18925 193704 191309  13010     0     0    25s  77%  56%  :   69%      0   823     0     0 17011 184149
88%     0     0     0     870 30881 170619 173407  31817     0     0    25s  80%  81%  Ff  70%      0   870     0     0 28689 163628
85%     0     0     0     749 21284 170047 173757  40782     0     0    26s  79%  80%  Ff  71%      0   749     0     0 19427 162471
85%     0     0     0     859 23649 186026 189312  12500     0     0     4s  81%  35%  Fs  69%      0   859     0     0 21597 180306
84%     0     0     0     842 22648 192688 184712  28976     0     0    25s  79% 100%  :v  61%      0   842     0     0 20534 183636
87%     0     0     0     802 24264 182101 182038  28218     0     0    26s  81%  68%  Ff  74%      0   802     0     0 22192 173628
84%     0     0     0     901 20371 192771 190167  11068     0     0     4s  80%  48%  Fn  80%      0   901     0     0 18414 186027
92%     0     0     0     764 18884 176920 183443  38519     0     0    27s  80%  98%  :   88%      0   764     0     0 17071 170033
84%     0     0     0     825 18148 196403 193556   4922     0     0    27s  81%  15%  Fs  73%      0   825     0     0 16220 187327
88%     0     0     0     815 19177 187406 187996  30802     0     0    27s  82% 100%  :f  70%      0   815     0     0 17295 180523
89%     0     0     0     767 26055 183221 176940  26357     0     0     3s  81%  78%  Ff  68%      0   767     0     0 23860 171445
88%     0     0     0     851 20917 184462 188274  23756     0     0     2s  79%  84%  :   75%      0   851     0     0 18964 178240
86%     0     0     0     766 21210 182773 174552  41666     0     0     2s  80%  68%  F   61%      0   766     0     0 19289 174251
88%     0     0     0     845 26713 183023 187870  25276     0     0    34s  81%  46%  Ff  67%      0   845     0     0 24558 176519
90%     0     0     0     811 29641 178850 175486  31514     0     0     2s  82%  82%  Ff  70%      0   811     0     0 27357 168555
88%     0     0     0     858 22592 184809 191006  19398     0     0    34s  77%  43%  :   85%      0   858     0     0 20433 178754
89%     0     0     0     846 27752 175803 174536  36638     0     0    34s  82%  83%  Ff  67%      0   846     0     0 25508 166298
86%     0     0     0     805 16477 186967 191742  18500     0     0     2s  79%  61%  Ff  76%      0   805     0     0 14599 178758
85%     0     0     0     819 23469 190576 188440  21521     0     0    35s  80%  60%  :   65%      0   819     0     0 21311 183667
89%     0     0     0     764 17247 176901 186320  36641     0     0    35s  81%  74%  Ff  67%      0   764     0     0 15381 170283
81%     0     0     0     849 23373 198727 195154   1305     0     0    35s  80%  12%  :   50%      0   849     0     0 21166 189826
SVUSFAS01> priv set diag
Warning: These diagnostic commands are for use by NetApp
         personnel only.
SVUSFAS01*>
SVUSFAS01*> sysstat         -M 1
ANY1+ ANY2+  AVG CPU0 CPU1 Network Storage Raid Target Kahuna WAFL_XClean SM_Exempt Cifs Exempt Intr Host Ops/s   CP
  93%   77%  86%  88%  83%     43%     29%  17%     9%    64%          0%        0%   0%     3%   6%   0%   925  26%
  93%   78%  86%  89%  83%     45%     28%  18%    10%    59%          0%        0%   0%     6%   7%   0%   812 100%
  91%   74%  83%  88%  79%     45%     29%  17%    10%    54%          0%        0%   0%     6%   7%   0%   796 100%
  92%   78%  86%  89%  84%     42%     29%  18%     9%    64%          0%        0%   0%     4%   7%   0%   824  36%
  97%   88%  93%  94%  93%     42%     32%  21%     9%    71%          0%        0%   0%     6%   6%   0%   759 100%
  88%   71%  81%  85%  76%     43%     29%  17%     9%    51%          0%        0%   0%     4%   7%   0%   852  77%
  89%   72%  81%  86%  76%     44%     32%  16%     9%    54%          0%        0%   0%     0%   8%   0%   829   0%
  87%   68%  79%  83%  74%     43%     29%  15%     9%    54%          0%        0%   0%     0%   8%   0%   901   4%
  93%   80%  87%  90%  85%     38%     31%  22%     8%    62%          0%        0%   0%     7%   6%   0%   800 100%
  91%   75%  84%  87%  81%     41%     31%  20%     9%    56%          0%        0%   0%     5%   7%   0%   780 100%
  89%   72%  81%  85%  77%     40%     30%  18%     9%    55%          0%        0%   0%     4%   7%   0%   824  77%
  86%   67%  78%  83%  73%     43%     31%  16%     9%    50%          0%        0%   0%     0%   7%   0%   815   0%
  87%   67%  78%  82%  73%     43%     31%  16%     9%    50%          0%        0%   0%     0%   7%   0%   826   0%
  86%   67%  78%  82%  73%     42%     31%  16%     9%    50%          0%        0%   0%     0%   7%   0%   832   0%
  83%   61%  73%  79%  68%     41%     28%  14%     8%    48%          0%        0%   0%     0%   7%   0%   739   0%
  86%   68%  78%  82%  74%     41%     31%  17%     9%    51%          0%        0%   0%     0%   7%   0%   852   0%
  91%   75%  84%  87%  81%     40%     31%  18%     9%    61%          0%        0%   0%     2%   7%   0%   856  19%
  94%   82%  89%  92%  86%     40%     32%  23%     9%    58%          0%        0%   0%     9%   7%   0%   705 100%
  90%   73%  82%  87%  77%     45%     28%  17%     9%    52%          0%        0%   0%     5%   7%   0%   794 100%
  92%   77%  85%  89%  82%     43%     34%  18%     9%    57%          0%        0%   0%     0%   8%   0%   916  12%
  96%   86%  92%  94%  90%     41%     30%  22%     9%    67%          0%        0%   0%     9%   6%   0%   853  75%
  91%   76%  84%  88%  80%     44%     32%  19%     9%    54%          0%        0%   0%     5%   7%   0%   813 100%
  89%   72%  81%  85%  77%     44%     31%  15%     9%    56%          0%        0%   0%     0%   7%   0%   846  13%
  88%   71%  80%  85%  75%     44%     31%  16%     9%    53%          0%        0%   0%     0%   7%   0%   841   0%
  94%   82%  89%  91%  86%     41%     30%  20%     9%    65%          0%        0%   0%     6%   6%   0%   757  91%
  93%   79%  87%  91%  83%     45%     32%  20%    10%    54%          0%        0%   0%     6%   7%   0%   838 100%
  89%   71%  81%  87%  76%     46%     28%  16%     9%    53%          0%        0%   0%     3%   8%   0%   792  74%
  89%   73%  82%  85%  79%     41%     28%  16%     8%    62%          0%        0%   0%     2%   7%   0%   785  27%
  90%   75%  83%  88%  79%     39%     33%  20%     9%    53%          0%        0%   0%     5%   7%   0%   921 100%
  91%   78%  85%  89%  82%     44%     31%  19%    10%    55%          0%        0%   0%     6%   7%   0%   798 100%
  90%   75%  84%  88%  80%     45%     32%  17%    10%    55%          0%        0%   0%     2%   7%   0%   853  51%
  94%   80%  87%  89%  86%     41%     30%  20%     9%    63%          0%        0%   0%     5%   7%   0%   785  51%
  93%   80%  87%  91%  84%     44%     32%  21%     9%    56%          0%        0%   0%     5%   7%   0%   795 100%
  90%   73%  83%  87%  79%     45%     30%  18%     9%    53%          0%        0%   0%     3%   7%   0%   826  75%
  88%   70%  80%  85%  76%     46%     30%  15%    10%    53%          0%        0%   0%     0%   7%   0%   847   0%
  91%   74%  84%  87%  81%     41%     27%  18%     9%    60%          0%        0%   0%     6%   6%   0%   748  57%
  90%   74%  83%  87%  79%     43%     30%  18%    10%    53%          0%        0%   0%     5%   7%   0%   851 100%
  89%   71%  81%  86%  77%     44%     29%  16%     9%    53%          0%        0%   0%     4%   7%   0%   894  74%
  88%   71%  81%  84%  77%     43%     28%  15%     9%    59%          0%        0%   0%     1%   7%   0%   806  14%
  95%   85%  91%  92%  89%     42%     32%  22%     9%    63%          0%        0%   0%     8%   6%   0%   873 100%
  90%   73%  82%  86%  78%     43%     31%  18%     9%    52%          0%        0%   0%     5%   7%   0%   786  97%
  90%   74%  83%  86%  80%     42%     33%  17%     9%    58%          0%        0%   0%     0%   7%   0%  1056   0%
  96%   87%  92%  92%  92%     36%     32%  21%     8%    75%          0%        0%   0%     6%   6%   0%   779  86%
  93%   48%  71%  91%  50%     34%     26%  16%     7%    48%          0%        0%   0%     5%   5%   0%   825 100%
  92%   76%  85%  89%  80%     42%     34%  19%     9%    55%          0%        0%   0%     3%   7%   0%   935  70%
  90%   73%  82%  86%  79%     43%     33%  16%    10%    56%          0%        0%   0%     0%   7%   0%   968   0%
  92%   77%  85%  87%  83%     39%     32%  19%     8%    63%          0%        0%   0%     2%   7%   0%   883  35%
  92%   77%  85%  88%  83%     38%     35%  21%     9%    55%          0%        0%   0%     5%   7%   0%   852 100%
  84%   65%  76%  80%  71%     37%     31%  19%     8%    44%          0%        0%   0%     5%   7%   0%   837 100%
  89%   71%  81%  85%  76%     42%     32%  17%     9%    52%          0%        0%   0%     2%   7%   0%   849  45%
  89%   72%  82%  86%  78%     44%     32%  16%    10%    54%          0%        0%   0%     0%   7%   0%  1008   0%
  87%   69%  79%  83%  74%     42%     31%  16%     9%    53%          0%        0%   0%     0%   7%   0%   859   0%
  92%   79%  86%  89%  83%     39%     35%  19%     8%    61%          0%        0%   0%     2%   7%   0%   836  17%
  93%   81%  88%  90%  86%     37%     33%  23%     8%    60%          0%        0%   0%     7%   7%   0%   687 100%
  92%   78%  86%  88%  83%     39%     33%  20%     8%    59%          0%        0%   0%     5%   8%   0%   735 100%
  91%   77%  85%  88%  82%     41%     37%  20%     9%    54%          0%        0%   0%     0%   8%   0%   811  91%
  89%   74%  82%  87%  78%     43%     33%  18%     9%    54%          0%        0%   0%     0%   8%   0%   801   0%
  92%   77%  85%  89%  82%     42%     35%  19%     9%    58%          0%        0%   0%     0%   8%   0%   867   0%
  94%   82%  89%  90%  88%     35%     33%  21%     8%    69%          0%        0%   0%     5%   7%   0%   766  43%
  90%   74%  83%  86%  80%     39%     33%  22%     8%    51%          0%        0%   0%     5%   8%   0%   751 100%
  95%   83%  89%  89%  89%     38%     32%  19%     9%    69%          0%        0%   0%     4%   6%   0%   864  96%
  87%   66%  78%  81%  74%     40%     31%  16%     9%    52%          0%        0%   0%     0%   7%   0%   893   0%
  87%   68%  78%  82%  75%     40%     33%  17%     9%    51%          0%        0%   0%     0%   7%   0%   880   0%
  81%   58%  71%  76%  66%     40%     27%  14%     8%    46%          0%        0%   0%     0%   7%   0%   750   0%
  93%   79%  87%  88%  85%     37%     34%  20%     8%    64%          0%        0%   0%     4%   6%   0%   944  63%
  92%   77%  85%  88%  81%     41%     34%  22%     9%    52%          0%        0%   0%     5%   7%   0%   823 100%
  88%   70%  80%  83%  76%     40%     31%  19%     9%    50%          0%        0%   0%     5%   7%   0%   806 100%
  88%   70%  80%  84%  75%     40%     32%  18%     9%    51%          0%        0%   0%     2%   7%   0%   874  53%
  88%   73%  82%  84%  79%     40%     34%  18%     9%    54%          0%        0%   0%     0%   8%   0%   819   0%
  89%   74%  83%  85%  80%     37%     36%  20%     9%    56%          0%        0%   0%     0%   8%   0%   877   0%
  90%   74%  83%  86%  80%     40%     35%  19%     9%    54%          0%        0%   0%     0%   8%   0%   903   0%
  93%   79%  87%  88%  85%     35%     33%  22%     8%    62%          0%        0%   0%     6%   7%   0%   807  85%
  93%   80%  87%  88%  87%     35%     35%  23%     8%    61%          0%        0%   0%     5%   7%   0%   843 100%
  94%   82%  89%  91%  87%     40%     36%  21%     9%    60%          0%        0%   0%     3%   8%   0%   870  96%
  87%   70%  80%  82%  78%     36%     34%  19%     8%    53%          0%        0%   0%     0%   8%   0%   892   0%
  85%   66%  77%  79%  74%     35%     33%  18%     8%    51%          0%        0%   0%     0%   8%   0%   776   0%
  88%   71%  80%  83%  78%     37%     35%  19%     8%    53%          0%        0%   0%     0%   8%   0%   821   0%
  96%   87%  92%  93%  91%     34%     36%  28%     8%    63%          0%        0%   0%     9%   7%   0%   766  70%
  94%   82%  89%  89%  89%     41%     36%  22%     9%    58%          0%        0%   0%     5%   8%   0%   837 100%
  91%   77%  85%  87%  82%     40%     36%  20%     9%    58%          0%        0%   0%     0%   8%   0%   935  43%
  88%   71%  80%  83%  78%     37%     34%  19%     8%    54%          0%        0%   0%     0%   8%   0%   891   0%
  84%   62%  74%  75%  73%     32%     32%  18%     7%    50%          0%        0%   0%     0%   8%   0%   911   0%
  90%   73%  83%  83%  83%     30%     32%  23%     7%    60%          0%        0%   0%     7%   7%   0%   678  81%
  87%   68%  79%  79%  79%     33%     34%  23%     8%    48%          0%        0%   0%     5%   8%   0%   840 100%
  89%   73%  82%  82%  82%     36%     36%  22%     8%    52%          0%        0%   0%     2%   8%   0%   831 100%
  85%   66%  77%  78%  75%     32%     35%  20%     7%    51%          0%        0%   0%     0%   8%   0%   764  70%
  82%   61%  73%  73%  73%     35%     32%  18%     7%    46%          0%        0%   0%     0%   8%   0%   811   0%
  95%   84%  90%  91%  89%     36%     36%  23%     8%    65%          0%        0%   0%     5%   7%   0%   747  52%
  94%   82%  88%  88%  88%     39%     38%  24%     9%    54%          0%        0%   0%     5%   8%   0%   799 100%
  91%   76%  85%  87%  82%     38%     36%  23%     9%    52%          0%        0%   0%     5%   8%   0%   858 100%
  88%   72%  81%  84%  78%     39%     32%  19%     9%    55%          0%        0%   0%     0%   8%   0%   844  79%
  91%   75%  84%  87%  81%     42%     33%  18%     9%    57%          0%        0%   0%     0%   8%   0%   826   0%
  96%   85%  91%  92%  91%     38%     36%  21%     8%    67%          0%        0%   0%     5%   7%   0%   717  72%
  98%   89%  94%  94%  94%     37%     45%  23%     8%    62%          0%        0%   0%     5%   7%   0%   859 100%
  99%   86%  93%  90%  95%     41%     41%  20%     9%    63%          0%        0%   0%     4%   7%   0%   795 100%
  98%   87%  93%  93%  94%     40%     45%  20%     9%    65%          0%        0%   0%     0%   8%   0%   806  20%
  93%   79%  87%  87%  87%     44%     36%  19%     9%    59%          0%        0%   0%     0%   8%   0%   899   0%
  98%   92%  96%  95%  96%     36%     33%  25%     8%    75%          0%        0%   0%     9%   7%   0%   703  92%
  93%   80%  87%  90%  84%     41%     34%  21%     9%    57%          0%        0%   0%     5%   7%   0%   781 100%
  89%   72%  82%  85%  78%     41%     33%  18%     9%    54%          0%        0%   0%     0%   8%   0%   864   7%
  85%   65%  76%  80%  72%     39%     31%  17%     8%    48%          0%        0%   0%     0%   8%   0%   830   0%
  88%   71%  80%  83%  77%     38%     34%  18%     9%    53%          0%        0%   0%     0%   7%   0%   856   0%
  84%   62%  74%  78%  71%     38%     30%  16%     8%    48%          0%        0%   0%     0%   7%   0%   924   0%
  90%   73%  82%  85%  80%     40%     34%  18%     9%    57%          0%        0%   0%     0%   7%   0%   931   7%
  94%   84%  90%  91%  88%     37%     33%  23%     9%    63%          0%        0%   0%     8%   6%   0%   829 100%
SVUSFAS01*>
SVUSFAS01*>
SVUSFAS01*>
SVUSFAS01*>
SVUSFAS01*> priv set admin
SVUSFAS01> priv set admin
SVUSFAS01> sysstat -us 1
CPU   Total    Net kB/s    Disk kB/s    Tape kB/s Cache Cache  CP  CP Disk
       ops/s    in   out   read  write  read write   age   hit time ty util
86%     867 19107 186295 195078  19297     0     0    19s  72%  39%  F  57%
83%     827 17729 187506 198704  29556     0     0    20s  76% 100%  :  60%
83%     823 23177 190773 185460  27432     0     0    20s  77% 100%  :  63%
82%     947 15740 192689 216359    591     0     0    20s  72%  14%  :  87%
89%     867 18941 178821 189363  34008     0     0    20s  74%  78%  F  87%
89%     938 24991 182085 202228  26052     0     0    20s  70% 100%  :  81%
85%    1008 18508 181986 217811  16187     0     0     4s  69%  63%  :  82%
87%     885 17294 171457 203789  17312     0     0    19s  70%  36%  F  80%
82%     913 12935 194753 191369  28428     0     0     4s  73% 100%  :  86%
88%    1020 23285 181893 198912  29312     0     0    19s  70% 100%  :  86%
82%    1060 15628 198290 206322    545     0     0    19s  69%  18%  :  82%
90%     933 19624 161673 206713  16213     0     0    19s  70%  36%  F  94%
80%     952 20927 171951 179936  24754     0     0    19s  73% 100%  :  81%
86%    1057 23251 166049 212930  28551     0     0    19s  74% 100%  :  80%
81%    1032 13071 179975 209598   9878     0     0    18s  73%  54%  :  92%
88%     838 14085 167546 192108  26696     0     0    18s  73%  52%  F  94%
81%     832 12097 181810 202371  29150     0     0    18s  72% 100%  :  74%
81%     850 20434 190375 183796  21594     0     0    18s  76%  79%  :  66%
81%    1065 17122 189364 218952      0     0     0     4s  71%   0%  -  68%
89%     915 17420 170598 189429  30906     0     0    19s  79%  45%  F  74%
86%     743 12210 185872 177484  27840     0     0     4s  80% 100%  :  83%
84%     826 21870 190831 188218  19011     0     0     4s  77%  66%  :  71%
81%     853 15935 195777 200663     20     0     0    20s  73%   0%  -  76%
84%     801 20914 190389 183839   9843     0     0    20s  79%  20%  F  66%
89%     767  9843 184961 194929  29674     0     0    20s  80% 100%  :  75%
83%     905 23716 196546 177070  26659     0     0    20s  81% 100%  :  65%
80%     903 15126 195730 195572  16832     0     0    21s  79%  65%  :  63%
80%     936 14738 197238 218238      0     0     0    20s  72%   0%  -  66%
89%     890 17288 172216 186941  42026     0     0     4s  80%  81%  F  78%
90%     875 12066 172453 198095  29388     0     0     3s  77% 100%  :  89%
76%     825 23177 168075 183616  10352     0     0     3s  76%  47%  :  71%
78%     927 13133 190172 210309     32     0     0     2s  75%   0%  -  76%
83%     763 14392 192691 178810  25214     0     0     2s  81%  59%  F  53%
88%     845 20078 188403 194720  30064     0     0     2s  77% 100%  :  82%
79%     885 15971 183346 200821  26713     0     0    27s  78% 100%  :  63%
80%     891 11787 195154 207612   6295     0     0    27s  78%  28%  :  76%
76%     797 14314 203478 187311      8     0     0    28s  81%   0%  -  56%
89%     745 18547 175438 170941  50551     0     0    28s  76%  90%  F  65%
82%     884 24638 188029 175356  25788     0     0    28s  79% 100%  :  58%
77%     881 10282 209941 211940     12     0     0    28s  81%   0%  -  57%
78%     848 17287 201761 188587     24     0     0    29s  79%   0%  -  63%
82%     694  8100 188552 171278  39754     0     0     2s  79%  74%  F  62%
77%     815  8982 193877 197471  28876     0     0    29s  76% 100%  :  60%
78%     831 11545 202374 204072   8562     0     0    30s  81%  46%  :  55%
77%     902 12679 205419 207445      0     0     0    30s  78%   0%  -  49%
73%     832 10918 203135 190773      0     0     0     2s  79%   0%  -  39%
76%     809 10310 206160 202258     32     0     0    31s  79%   0%  -  55%
75%     845 12663 210855 200724      0     0     0    31s  78%   0%  -  53%
88%     789 13517 171193 187466  46397     0     0    31s  79%  97%  F  62%
82%     804 13837 194625 184071  29055     0     0    31s  76% 100%  :  87%
80%     796 17486 193438 178841   1003     0     0    31s  80%  29%  :  93%
69%     776  7947 183766 172525      0     0     0    32s  70%   0%  -  94%
75%     813 11955 174718 176877     24     0     0    31s  70%   0%  - 100%
71%     683  7952 140887 157392  15452     0     0    32s  65%  44%  F 100%
83%     860 19955 158896 165064  32268     0     0     2s  67% 100%  : 100%
79%     782 18617 156726 156703  22837     0     0    32s  66% 100%  : 100%
73%     763 16225 161897 169972   6864     0     0    31s  63%  97%  :  97%
83%     807 19062 163780 173912  15436     0     0    31s  74%  46%  F  95%
80%     769 11882 169147 181373  29162     0     0    30s  69% 100%  :  89%
88%    1016 19624 175977 198867  28020     0     0    30s  71% 100%  :  93%
76%     912 16421 182875 171581   4273     0     0    30s  76%  36%  :  90%
89%     741 21258 172594 172569  26352     0     0    29s  73%  47%  F  93%
88%     722 16612 177127 172812  36108     0     0    29s  71% 100%  :  96%
89%     906 23189 183421 195178  13389     0     0    27s  76% 100%  :  97%
83%     914 21610 191940 178963     99     0     0    26s  75%  32%  :  96%
85%     773 14935 151645 166409  42090     0     0    27s  62%  89%  F  98%
83%     870 16569 167205 187221  30014     0     0    26s  67% 100%  :  98%
76%     757 14235 154981 173888  12624     0     0    26s  64% 100%  : 100%
82%     931 17116 178098 207821    131     0     0    24s  73%  33%  :  96%
91%     959 14677 173279 206699  22331     0     0    23s  65%  55%  F  95%
Summary Statistics (   70 samples  1 secs/sample)
Min
69%     683  7947 140887 156703      0     0     0     2s  62%   0%  *  39%
Avg
82%     861 16322 182756 190607  18342     0     0    20s  74%  59%  *  78%
Max
91%    1065 24991 210855 218952  50551     0     0    32s  81% 100%  * 100%
SVUSFAS01>
SVUSFAS01>
SVUSFAS01>
SVUSFAS01>
SVUSFAS01>
radek_kubka
Hi,
I'd say your filer is just 'normally' busy - i.e. it is trying to cope with a lot of iSCSI traffic, mostly reads, but some writes at the same time as well.
NVRAM is almost constantly full, hence a lot of Ff-type consistency points, where NVRAM is flushed to disk.
No wonder CPU utilisation is high.
Regards,
Radek
NAYABRASOOL
What is F-Type CP's ???  and also could you please tell how to overcome this High Usage??
radek_kubka
F means NVRAM full, the second (lowercase) f means flushing NVRAM content to disk.
To lower CPU usage you need to hammer your filler less!
NAYABRASOOL
Hmmm Good One
So no other go other than this like changing some parameters will help me to overcome this ??
radek_kubka
Well, not much really.
As there are many reads from LUNs, I'd probably run reallocate measure on the volumes containing LUNs to see whether fragmentation is playing any role.
NAYABRASOOL
How i will be able to run the reallocation and how to check the fragmentation ??
Is the command
FAS01> reallocate start <vol-path> will do , will it have any impact if i run this command ???
radek_kubka
I actually provided the command to check the fragmentation:
reallocate measure <vol_path>
Before running actual reallocation (reallocate start) gave a good read about different caveats & parameters, e.g.:
https://communities.netapp.com/message/20969#20969
https://communities.netapp.com/message/84099#84099
https://fieldportal.netapp.com/home.aspx?oparams=68936
NAYABRASOOL
Hi Radek,
I was able to open only the first link rest of all showing as UNAUTH access
Thanks,
Nayab
NAYABRASOOL
Hi Radek,
I have run the reallocation But how i can see if the fragmentation is the cause for the CPU high usage will it give me some message else how i can trace it out.
Thanks,
Nayab
radek_kubka
Hi Nayab,
regards,
Radek
madden
Hi,
I agree with Radek; this system is simply near bottleneck.
Take a look at this snippet:
Min
Avg
Max
From the Average row:
82% CPU: Quite high.  Checking the sysstat -M output it looks balanced around processing functions
183 MB/s reads + 16 MB/s writes = 199 MB/s network xfer: You are using at least 2 x GbE links.  You might hit link bottleneck if traffic is not balanced.
861 IOPs:   take the 199MB/s / 861 IOPs = 231 KB / op.  So you are doing large IOs.
78% disk busy: Above 50% and you can already start to see some variability in latency.  At 78% average the disks are quite busy; they are processing at least one xfer 78% of the time so likely some IOs are also waiting to be processed at times.  If IOs are waiting at the disk layer these will eventually make IOs wait on the host side.
Disk IO efficiency: Disk read is 190MB/s, network out is 182 MB/s which is roughly balanced.  Disk write is 18MB/s, network in is 16MB/s which is roughly balanced; the extra little bit is parity.  You have no evidence of freespace fragmentation.
Reallocate is useful if you have freespace fragmentation (you don't) or if you have sequential read after random write (you seem to be doing large block IO so I doubt it).  Even then, it is has a bigger impact on reducing disk busy than cpu busy.  Checking your disk IO efficiency however I'd say it looks pretty good; network in/out matches disk in/out.
So across the main system aspects (CPU, Disk IO, Network) on each you are nearing bottleneck.  The solution is to stay as-is and be satisfied with latency you have, reduce workload (or move to the other head if it is less busy) and see latency improve, or buy a more powerful controller.
Hope that helps!
Christopher Madden
Storage Architect, NetApp EMEA
NAYABRASOOL
Hi Radek,
Thanks a lot for making me to understand things better hope will run the reallocate and will see for the optimization value.
Madden,
Thank you so much for your crystal clear explanation about the busy stats from the output above. We are looking forward to buy a High end filer and migrate all our stuff to the new one .
And also I am confused whose response i need to mark as CORRECT ANSWER so that it will be helpful for others .
Thanks,
Nayab
radek_kubka
Fragmentation / reallocation is a bit of a side-tracking really, as it is fairly obvious your system is under heavy load - so I suggest you mark one of the answers mentioning this as correct.
(I actually think when people search communities, they tend to read a whole thread anyway, rather than looking only at the "correct" answer without its context)
