ONTAP Hardware
CRC-Error Messages seen since Ontap Upgrade to 9.3P7
klmi
Dear Community,
since we have updated some of our systems (FAS82xx, AFF A300) to Ontap 9.3P7,
we see the following Errors in Messages for our (UTA2) 10GBit LAN-Ports, which have not been here before the update.
10/16/2018 11:04:14 <Filer>-<node>   ALERT         vifmgr.cluscheck.crcerrors: Port e0g on node <Filer>-<Node> is reporting a high number of observed hardware errors, possibly CRC errors.
ifstat shows TotalErrors (increasing) and Errors/Minute but no CRC-Errors
-- interface  e0g  (1 hour, 42 minutes, 32 seconds) --
RECEIVE
 Total frames:    56798k | Frames/second:    9233  | Total bytes:       178g
 Bytes/second:    28949k | Total errors:     1337  | Errors/minute:      13
 Total discards:      2  | Discards/minute:     0  | Multi/broadcast: 31503
 Non-primary u/c:     0  | CRC errors:          0  | Runt frames:        18
 Fragment:            0  | Long frames:      1319  | Alignment errors:    0
 No buffer:           2  | Pause:               0  | Jumbo:               0
 Noproto:           105  | Bus overruns:        0  | LRO segments:    50798k
 LRO bytes:         174g | LRO6 segments:       0  | LRO6 bytes:          0
 Bad UDP cksum:       0  | Bad UDP6 cksum:      0  | Bad TCP cksum:       0
 Bad TCP6 cksum:      0  | Mcast v6 solicit:    0
TRANSMIT
 Total frames:    16298k | Frames/second:    2649  | Total bytes:     11749m
 Bytes/second:     1909k | Total errors:        0  | Errors/minute:       0
 Multi/broadcast:   605  | Pause:               0  | Jumbo:            6655k
 Cfg Up to Downs:     0  | TSO non-TCP drop:    0  | Split hdr drop:      0
 Timeout:             0  | TSO segments:      840k | TSO bytes:        9910m
 TSO6 segments:       0  | TSO6 bytes:          0  | HW UDP cksums:       0
 HW UDP6 cksums:      0  | HW TCP cksums:       0  | HW TCP6 cksums:      0
 Mcast v6 solicit:    0
DEVICE
 Mcast addresses:     4  | Rx MBuf Sz:       4096
LINK INFO
 Speed:           10000m | Duplex:            full | Flowcontrol:       none
 Media state:     active | Up to downs:          2
From my feeling it looks like a BUG in Data Ontap 9.3P7 (Error in their Portstats, ...), as we dont find any matching Errors in our Network infrastructure. Also no impact seen to the systems.
I already opened a support Case, but uptonow they cannot match this to an existing BUG, as 9.3P7 should have fixed all issues regarding this problem.
So timeconsuming debugging on customer site must be done to find the root-cause 😞
So the Question to the community: Anybody  seen this Errors on Ontap 9.3P7?
Best Regards,
Klaus
1 ACCEPTED SOLUTION
klmi
Hello,
short update on this topic:
it seems like the issues are really related to the Case, that we receive Packets with MTU-Size >1500,  while the Port is set to MTU1500.
Starting with Ontap 9.3 this issue gets reported als "long frames" an in the events and alerts.
Our solution for a permanent fix is,
to set the MTU to 9000 on LAN-Ports on the Filer which are connected to a Switch with Jumbo Frames enabled.
Thanks Gidi for your feedback which helped much to solve the issue.
Best Regards,
Klaus
28 REPLIES 28
buraksenturk
Hi @LORENZO_CONTI
port set to switches 9000 and also port set netapp 9000.
thats example from customer;
switch;
  TX
    1916130391 unicast packets  2666708 multicast packets  20843127 broadcast packets
    1939643557 output packets  136406204523 bytes
    3331 jumbo packets
    3331 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
netapp;
RECEIVE
Total frames:      551m | Frames/second:     197  | Total bytes:     36893m
Bytes/second:    13145  | Total errors:     3372  | Errors/minute:       0
 Total discards:      0  | Discards/minute:     0  | Multi/broadcast: 23737k
Non-primary u/c:     0  | CRC errors:       3370  | Runt frames:         2
 Long frames:         0  | Alignment errors:    0  | No buffer:           0
 Pause:               0  | Jumbo:              42  | Noproto:             0
 Bus overruns:        0  | LRO segments:      100  | LRO bytes:       11072
 LRO6 segments:       0  | LRO6 bytes:          0  | Bad UDP cksum:       0
 Bad UDP6 cksum:      0  | Bad TCP cksum:       0  | Bad TCP6 cksum:      0
 Mcast v6 solicit:    0
PKoza
We have same Error since 5 Month, NetApp does not find a solution.
The port we have problems with, is e0M (Management).
e0M can not be higher than MTU 1500, Switch is configured too on MTU 1500 and with 1000 Mbps.
paul_stejskal
PKoza can you post your ifstat output for that port?
PKoza
Here it is attached.
PeterPie
I'm getting the same errors with long frames and length errors with our e0M ports and we upgraded to our ONTAP 9.7P10
Did you find any solution to this issue.
paul_stejskal
Did you follow the action plan in this KB? https://kb.netapp.com/Advice_and_Troubleshooting/Data_Storage_Software/ONTAP_OS/Ifstat_output_reports_long_frames
Your port is getting larger than configured MTU frames, and ONTAP is correctly discarding because it is invalid and possibly misconfigured.
PeterPie
I went over the ifcommands with support , also our networking team, confirm that the ports for the mgt ports e0M are set with MTU of 1500 on and also on the switches
network port show below that it is healthy ,but still getting those errors.  We even replaced the network cables on all 4 E0m ports
Speed(Mbps) Health
Port IPspace Broadcast Domain Link MTU Admin/Oper Status
e0M Default mgmt up 1500 auto/1000 healthy
Still trying thought
