ONTAP Hardware
Can 25GbE sfp operate on 10Gb ?
AlexeyF
Hi
I wonder if 25GbE SFP28 ports can operate on 10Gb ?
we have X65404 model transceivers
are there any limitations ?
Thanks
1 ACCEPTED SOLUTION
AlexDawson
Unfortunately not - optical ethernet transceivers are always single rate. Please contact your account team to obtain pricing for appropriate transceivers.
7 REPLIES 7
AlexDawson
JonathanGaudette
No, a 25gbit SFP is 25gbit only.
AlexeyF
Do these ports support RS-FEC ?
andris
Typically, the 25GbE ports on the platform support RS-FEC - usually autonegotiated. You'd have to provide specific platform and NIC/card details to get a 100% answer.
kate365
Yes most 25GbE SFP28 ports and transceivers including the X65404 model support backward compatibility with 10GbE. However this depends on the switch or NIC firmware and configuration. Check the device documentation to confirm compatibility and required settings.
andris
The NetApp official support statement is that X65404 transceiver is for 25GbE, only.
jhubert
Not accurate - while dual rate SFPs exist, all SFP28's that NetApp currently sells only support a single speed 10Gb or 25Gb.
