ONTAP Hardware
Can a 2240-4 run off of a single power supply?
VIRTUALLYMIKEB
The FAS2240-4 comes with four power supplies.  If three of them fail for some reason, can the system run on just the one remaining power supply?
1 ACCEPTED SOLUTION
aborzenkov
No. It needs at least two PSU providing power. It also needs all four PSU fans; physically removing PSU will cause shutdown after 2 minutes.
2 REPLIES 2
aborzenkov
VIRTUALGEEK2
they require a minimum of one per controller/per shelf. Anything less and they will shut down
