ONTAP Hardware
Cluster interconnect ports to use
Kamal
Hi We have received FAS8300 with 2 10G DAG Cable 25G DAG Cable.
e0a to e0a and e0b to e0b is connected with 10G DAG
e0c to e0c and e0d to e0d is connected with 25G DAG
but i only see e0c and e0d has online and configured with cluster
i do not see e0a and e0b.
when i list network ports, it shows e1a and e1b instead of e0a and e0b.
Can someone suggest better option here and can i use e0a and e0b for data purpose.
1 ACCEPTED SOLUTION
SpindleNinja
https://library.netapp.com/ecm/ecm_download_file/ECMLP2858856
Check out the switchless cluster cabling.
HA Interconnect 25GbE ->    (I don't think you would see these in net port show. )
e0a -> e0a
e0b -> e0b
Clusternet -> 100GbE
e0c -> e0c
e0d -> e0d
Host connections will be e0e -> e0h.   Or whatever other expansion cards are in there (e1a / e1b) .
2 REPLIES 2
SpindleNinja
e0a -> e0a
e0b -> e0b
e0c -> e0c
e0d -> e0d
Kamal
Thanks
Yes it does not show e0a and e0a, but it shows e1a and e1b.
