ONTAP Hardware
Configure HA and share discs
EMP
Hello,
Could you please tell me how to configure HA mode between two controllers of one FAS 2240 and how to share all discs so they can be managed by both controllers.
current configuration.
Controller 1:
e0a: flags=0x9f4c867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
ether 02:a0:98:52:fb:62 (auto-1000t-fd-up) flowcontrol full
trunked VIF1
e0b: flags=0x9f4c867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
trunked VIF1
e0c: flags=0x9f4c867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
trunked VIF1
e0d: flags=0x9f4c867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
trunked VIF1
e0M: flags=0x2b4c867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM,MGMT_PORT> mtu 1500
inet 10.100.101.61 netmask 0xfffffe00 broadcast 10.100.101.255 noddns
ether 00:a0:98:52:fb:67 (auto-100tx-fd-up) flowcontrol full
e0P: flags=0x2b4c867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM,ACP_PORT> mtu 1500 PRIVATE
inet 192.168.1.230 netmask 0xfffffc00 broadcast 192.168.3.255 noddns
ether 00:a0:98:52:fb:66 (auto-100tx-fd-up) flowcontrol full
lo: flags=0x1b48049<UP,LOOPBACK,RUNNING,MULTICAST,TCPCKSUM> mtu 9188
inet 127.0.0.1 netmask 0xff000000 broadcast 127.0.0.1
losk: flags=0x40a400c9<UP,LOOPBACK,RUNNING> mtu 9188
inet 127.0.20.1 netmask 0xff000000 broadcast 127.0.20.1
VIF1: flags=0x22f4c863<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
inet 10.100.10.60 netmask 0xfffffe00 broadcast 10.100.10.255
ether 02:a0:98:52:fb:62 (Enabled interface groups)
Controller 2:
ether 02:a0:98:51:e6:84 (auto-1000t-fd-up) flowcontrol full
trunked VIF02
trunked VIF02
trunked VIF02
trunked VIF02
e0M: flags=0x210c866<BROADCAST,RUNNING,MULTICAST,TCPCKSUM,MGMT_PORT> mtu 1500
inet 192.168.0.220 netmask 0xffffff00 broadcast 192.168.0.255 noddns
ether 00:a0:98:51:e6:89 (auto-100tx-fd-cfg_down) flowcontrol full
inet 192.168.2.49 netmask 0xfffffc00 broadcast 192.168.3.255 noddns
ether 00:a0:98:51:e6:88 (auto-100tx-fd-up) flowcontrol full
VIF02: flags=0x22f4c863<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
inet 10.100.10.59 netmask 0xfffffe00 broadcast 10.100.10.255
ether 02:a0:98:51:e6:84 (Enabled interface groups)
9 REPLIES 9
Sahana
Hi,
use storage failover modify -mode ha -node nodename to configure node in HA mode. Refer https://library.netapp.com/ecmdocs/ECMP1511539/html/storage/disk/assign.html to assign disks.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
EMP
Hi,
I thought that i need to configure "options cf.mode ha" for each controller?
Regarding disks:
I am not able to find the exact comand which i need to enter to share all dicsks between two controllers:( First controller owns 33 disks second one owns 3 discs. Is it possible to give me some advice with command which i need to enter.
Thank you!
Sahana
Which OS are you running? : 7 mode or cluster mode?
EMP
Os is 7.
aborzenkov
You can't share disks between controllers. Each disk is assigned to one controller and only this controller can manage it.
EMP
Hi,
I want to put two controllers in HA and share disks for whole HA.
Sahana
To enable HA in 7 mode. Refer https://library.netapp.com/ecmdocs/ECMP1210206/html/GUID-4C82CAA6-7010-4112-BA47-A58A040D1573.html
I am assuming that there is no data on the system.
You can change the disk ownership to distribute the disks equally among the HA pair.
Run disk show
Select the disks you want to change the ownership for. Ex 0c.00.14
disk assign 0c:00:14 -s unowned -f
disk show -n
will now show the disk owner as Not owned
Run disk assign 0c:00:14 -o othernode
Verify the change in ownership using disk show.
EMP
Hi,
There is important data when we need to keep. i hope that this process will not erase whole information.
Sahana
In that case, aggregate ownership also needs to be checked. Please contact Netapp support so they can guide you.
