ONTAP Hardware
Connection without IP
ZelChief
Hello!
I got FAS2020 and I don't know its IPs. Does exist any way to connect to NetApp without information about IP address?
1 ACCEPTED SOLUTION
SpindleNinja
if you're local you can use a serial cable and connect into it.
1 REPLY 1
SpindleNinja
