ONTAP Hardware
Data interface lif for fcp has Failover Policy: disabled. Is it correct?
areti
Good afternoon!
I have NetApp FAS2552 ONTAP 9.1 Cluster HA (two nodes).
In the Network Interfaces settings I can see that the data interface lif for cifs has Failover Policy: system_defined. It's good.
But the data interface lif for fcp has Failover Policy: disabled. Is it correct? In this case, will fault tolerance be ensured when rebooting or shutting down one of the two nodes?FailoverPolicy.jpg
1 ACCEPTED SOLUTION
SpindleNinja
FCP or iSCSI lifs don't failover.   Your hosts need to rely on multipathing for failover.
1 REPLY 1
SpindleNinja
