ONTAP Hardware
Difference between export ans share
Vinodma
Hi,
I am new to NetApp, and trying to find the difference between Exporting a Qtree and Share a Qtree?, i have a doubt if this is related to Linux/Windows client??
1 ACCEPTED SOLUTION
asulliva
Hello @Vinodma,
Generally speaking, an export refers to accessing the data via NFS whereas a share refers to accessing the data using CIFS/SMB.
Hope that helps.
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
2 REPLIES 2
asulliva
Hello @Vinodma,
Hope that helps.
Andrew
Vinodma
Hi Andrew,
Thank you so much for your reply
