ONTAP Hardware
Disks on FAS2240-4
grant
Dear All
I have a FAS2240-4 7-mode HA where we have to add a new disk shelf DS4243 for capacity expansion could you please verify if the steps below are corect in order to add all the new disk to the existing aggregate:
1. after the H/W installation we have to  check that new disks are available with command disk show -n
2. add the disks to existing aggregate (aggr1) wtih the command: aggr add aggr1 -d v5.22 v.523 v.524 ..........etc
3. expand the volumes
Thanks and Regards
Grant
4 REPLIES 4
aborzenkov
Before adding disks to aggregate you need to assign them to correct controller (disk assign). Depending on your configuration it may happen automatically and it may be wrong (see description of disk.auto_assign option).
grant
Hi
if disk disk.auto_assign option is on then it means that no other steps nedded?
grant
Hi again
to be more specific I have to add a new self with 24x 2TB disks, is it possible to add all the new disks on the existing aggregate?
BR
Grant
aborzenkov
No; all other steps are still required.
Yes, as long as total aggregate size will not exceed platform limits (check HWU).
